Pulling out my hair - Kawasaki ZX-10R.net
post #1 of 11 Old 08-26-2006, 05:11 PM Thread Starter
!v@n's Avatar
Send a message via AIM to !v@n Send a message via Yahoo to !v@n
Pulling out my hair
Please help me, my 10 is acting up. when i turn it on with the kick stand down and turn on the right blinker the bike turns off. i already replaced the kick stand switch. also the bike stays on when put into gear with the stand down. sometimes my turn signals wont work, or they will turn off when i pull the clutch in while riding. i dont know what the hell is going on. i've figured out that it's an electrical problem but what should i try. if anyone can give me some advice please help. my mechanic is pretty stumped as well. and i dont want to pay to have them take forever to figure it out $65 an hour can add up very quickly.
post #2 of 11 Old 08-26-2006, 06:51 PM
bluedevil's Avatar
Moved to this section:
Now, I don't like troubleshooting on the internet but try this and I will see if I can come up with somemore ideas. Disconnect the clutch lever switch(black 2 pin/wire connector at the handle bar) and start the bike, then see if you blinkers cause the shutdown still. It really looks like 2 different issues right now but want to make sure. So far I suspect the left handle bar Switch housing but the kick stand issue throughs in another wrench...still could be related though and this might help for a test.
bluedevil is offline
post #3 of 11 Old 08-26-2006, 08:31 PM Thread Starter
!v@n's Avatar
thanks i will try this
post #4 of 11 Old 08-26-2006, 09:49 PM Thread Starter
!v@n's Avatar
it still turns off with the clutch switch disconnected
post #5 of 11 Old 08-26-2006, 11:53 PM
bluedevil's Avatar
then it's looking more and more like a short or bad left housing switch. make sure you tried starting and shuting down with the kickstand down and up using the blinker controls...should not make a difference but if certain wires are touching it could...will look to see if I find something from the schematic tomorrow that could cause this
post #6 of 11 Old 08-27-2006, 12:14 AM
ZXTOM's Avatar
Dam dude, that shit sounds really F'uped............
But its probaly something real simple like a wire going to ground some where....
always is!.....
ZXTOM is offline
post #7 of 11 Old 09-01-2006, 12:35 PM Thread Starter
!v@n's Avatar
Well after much thinking and trying to figure out what the hell was going on, i decided to just completely replace the main wiring harness to the bike. Now the bikes has no glitches, and it is running like a champ. The whole thing took me like three hours to replace, but I had spent a lot more just scratchin my head trying to figure out where to start. I also probably saved me some money because I know a mechanic would have charged me a lot just for him to try to figure it out. Thanks to those who offered me advice.
post #8 of 11 Old 09-03-2006, 11:36 PM
I Am Having Some Problems Myself. Do You Run A Power Commander, If So, Try Disconnecting It And See.
pec2903 is offline
post #9 of 11 Old 09-04-2006, 03:00 AM Thread Starter
!v@n's Avatar
yeah i do have a power commander , but that wasn't the problem, i disconnected it and it was still acting up. after i changed the wiring harness it is all good even with the power comander.
post #10 of 11 Old 09-04-2006, 05:33 AM
Just To Let You Know. A Good Friend Of Mine Had To Have His Wiring Harness Replaced But It Sounds To Me That The Power Commander Could Have Been The Original Problem. You Never Know About This Electronic Stuff. By The Way Can You Tell Me You're Problem Symptoms Before You Replaced Wire Harness. My Bike Tops Out At 136 Mph (now). 4-5 Weeks Ago 181 Mph. I Think It Could Be Electrical, Too. In The Upper Rpms It Is Extremly Weak And Almost Feels Like It Boggs Down, It Struggles To Go Beyond 10,000 Rpm.
pec2903 is offline
BD...from back when he had hair... hillcountry10r Pictures and Videos 11 07-29-2006 08:23 PM
Bike on dyno pulling some big numbers toedragger24 Pictures and Videos 9 12-27-2005 01:53 PM
"BD" JUST GOT A HAIR TRANSPLANT.. R1GSXRKILLER Pictures and Videos 5 05-25-2005 05:56 PM
