PSA: 04 Kickstand Safety Switch Causing Cutout at 10,000 RPM - Kawasaki ZX-10R.net
post #1 of 5 Old 04-19-2008, 07:59 PM Thread Starter
kz2zx's Avatar
I had an intermittent cutout at around 10,000 RPM when the air temp was under 90'.
Sucked while leaned over, and sucked while racing.
I removed the kickstand safety switch (kickstand was long removed), and crimped the wires together in a blind terminal.
No more issues.
If you have a strange miss/cutout at higher revs, this may be your culprit. Another place to check is the bar killswitch.
HTH,
Fat, drunk, and stupid is no way to go through life, son
ASMA 47
WERA 147
kz2zx is offline
post #2 of 5 Old 04-19-2008, 08:04 PM
bluedevil's Avatar
No more issues.
HTH,
yep, the kick stand is part of many safety measures....but only vibration can cause what you described and should have nothing to do with RPMs :headshake
bluedevil is offline
post #3 of 5 Old 04-19-2008, 08:42 PM Thread Starter
kz2zx's Avatar
I'm going to go out on a limb here, and guess you've never had a 'Signals and Systems' class in college, have you? I'll even guess that terms like 'frequency domain' and 'harmonic coupling' aren't ringing bells.
That switch is getting sampled at some frequency, obviously. At some frequency the buzz breaking the contact is aligning with the sample frequency or a harmonic of it.
It has everything to do with frequency.
I was on the bike, thanks.
The '05 636 I had had the same issue, too. Same fix, same frequency/RPM.
ASMA 47
WERA 147
kz2zx is offline
post #4 of 5 Old 04-19-2008, 09:09 PM
McHaggis's Avatar
"The key to immortality is first living a life worth remembering"-Bruce Lee
McHaggis is offline
post #5 of 5 Old 04-19-2008, 09:09 PM
Starbucks Connoisseur
Static IP's Avatar
Huh? What?
are you talking about a song?
09' Ice Blended Peppermint Mocha Frappuccino
10' Venti Mocha Latte spilled some of it, was too hot
11' Peppermint Mocha W/Extra Shot of Espresso
12' Eggnog Venti Latte
13' Bagel
14' Standard Drip (since a Venti latte went up 20 cents)
Static IP is offline
where to buy upper fairing with single light cutout? inginekilla Performance and Tech 1 02-22-2007 10:19 PM
The Zx-10r Is Causing Brain Damage Gurm 10 The Out House 11 03-29-2006 08:51 AM
Anyone remove their kickstand and switch? yehzx10r Performance and Tech 4 08-03-2005 07:02 AM
Brakes hanging, causing bad shimmies... JonnyQuest The ZX-10R 6 11-09-2004 01:14 PM
Coolant leak pics - what do you think is causing it? Ghost The ZX-10R 17 08-10-2004 07:57 PM
