Projector headlight conversion ALMOST complete...Need your HELP - Kawasaki ZX-10R.net
post #1 of 45 Old 04-06-2006, 02:15 PM Thread Starter
Rspec99's Avatar
Images: 11
I have never been pleased with the headlight performance of my ZX10R. I seldom ride at night, but the times that I have, I was dissapointed at how poor the illumination was. As many of you have done as well, I adjusted the reflectors, and used brighter bulbs, all with no success. I have an HID kit, and it definitely puts out more light but the light dispersion is poor in comparison to the HID projectors on my Honda S2000.
For my project, I ended up using the projector lamps from an '05 Yamaha R1. It took some trimming but it fits beautifully in place of the reflector on the ZX10R. I even retained some adjustability via the stock adjusters. Even though these projectors were not HID specific, the lighting pattern, and intensity is incredible.
Anyhow, I will post pics and a brief step by step once I complete this project. However, I have one last problem that I need to solve and I hope someone might have an idea here.
The bulb mount on the R1 projector is a little longer than the ZX10R's and extends farther out the back of the headlight unit. As a result, I cannot use the stock screw on headlight caps to seal the unit. I could cut out a 2 3/8" hole in the cap, and it would fit perfectly. The problem is, the gaps will let in debris and water into the headlight unit housing and that is unacceptable.
Thanks guys! I have been staring at this for far too long, and figure someone with a fresh perspective might see something I am missing.
Rspec99 is offline
post #2 of 45 Old 04-06-2006, 02:22 PM
dnwhoop02 is offline
post #3 of 45 Old 04-06-2006, 02:28 PM Thread Starter
Rspec99's Avatar
Images: 11
I knew that was coming..... lol
Rspec99 is offline
post #4 of 45 Old 04-06-2006, 02:28 PM
Jay
I was thinking about this for the HID conversion kit where you need to drill the caps for the wires to come out.
Try finding a rubber electrical grommet. Carve the hole out a bit bigger to allow for the grommet.
Post pics dude so we can see how you did it, and what your situation is.
Jay is offline
post #5 of 45 Old 04-06-2006, 02:46 PM
Spacecoast 10R's Avatar
Rspec,
Pics of how it is right now would help with our thought process.
But Jay is heading in the right direction. You might be able to find some type of rubber 'o' rings of grommet in the electrical or plumbing areas of a hardware store. Lowes or Home Depot might have something, but Ace usually has a better selection of oring and such.
"Any man who says he is an AMERICAN, but something else also, isn't an AMERICAN at all.
We have room for but one flag, the AMERICAN FLAG .... We have room for but one language here, and that is the ENGLISH LANGUAGE...
And we have room for but one sole loyalty and that is a loyalty to the AMERICAN PEOPLE" TR
Spacecoast 10R is offline
post #6 of 45 Old 04-06-2006, 02:49 PM
You know what might also work, depending on the size of the gap and if it is the same size all the way around. You might be able to use the rubber spilnes that hold screens on doors or pool enclosures, but the biggest I have ever seen that is 1/8" - 3/16" in diameter.
Just another thought.
post #7 of 45 Old 04-06-2006, 02:49 PM
Jay
I have used the ones from radio shack before in boating applications for wires.
http://www.radioshack.com/product/in...entPage=search
Jay is offline
post #8 of 45 Old 04-06-2006, 02:53 PM
Speaking of boating applications. I have seen on some boats large gromets used where cables or wires go thru the firewalls on the boats to protect the fiberglass.
Even if you could find 'U' shape small rubber channel in lengths, that might do the job.
post #9 of 45 Old 04-06-2006, 02:59 PM
Jay
Exactly, coming from a boater myself also.
Definately, post some pics rspec, it would help ALOT.
Jay is offline
post #10 of 45 Old 04-06-2006, 03:13 PM
I have two other ideas.
1. You might want to look at the various rubber weatherstripping for the automotive industry or even the various weatherstripping available for the homes.
2. This is the redneck engineering in me coming out. (If is was mykl it would be coonass , had to be said) but anyways. A quick and dirty way would be to try and split vacuum line or something as flexible as that and slide it over the edge of the cover just like a grommet.
Just some more thoughts. I've put more thought into this thread than I have work today. But this is more fun.
2005 zx 10 Complete Suspension Set up gpz Performance and Tech 19 05-18-2017 04:34 PM
04/05 ZX10R Hydraulic Clutch Conversion? Larry Grogan The ZX-10R 11 02-22-2006 10:23 PM
Useless Information Louks03 The Out House 4 05-03-2005 03:33 PM
520 conversion talk Lyzic Performance and Tech 8 03-23-2005 02:13 PM
[email protected]@K; Contest-win a 520 conversion 16 Tooth CS NWZX10 The ZX-10R 33 02-18-2005 02:28 AM
