Problem removing head - Kawasaki ZX-10R.net
post #1 of 10 Old 04-08-2006, 09:08 PM Thread Starter
ninja3030's Avatar
Hi guys,
I'm currently changing my head gasket for a Muzzy. The head unbolted, but it's stuck on motor case. Is there any trick to free the head loose? I suppose that it's not a good thing to use a screwdriver and a hammer
And for those who have degreed their cam, were you able to do it with engine in frame? Because I currently do my head gasket without removing it.
Thanks!!
Yannick (Ninja3030)
ninja3030 is offline
post #2 of 10 Old 04-08-2006, 09:52 PM
10 speed's Avatar
oh man it has been awhile sence i did this....uhhh make sure all bolts are out. then hit it with a rubber mallet. there are pins to align it. so pull up on it. damn it has been about 4 months sence i did that..... i think we did pry on it a little however DONT use the screwdriver and a wedge you'll destroy your cases.
I got tiered of buying go fast parts.... So i got a turbo! now i need go slow parts!
If it aint modded it aint yours!
10 speed is offline
post #3 of 10 Old 04-09-2006, 09:31 AM
TC24's Avatar
Got to pull it to degree the cam.
'05 ZX-10R
'09 Streetglide
TC24 is offline
post #4 of 10 Old 04-09-2006, 09:45 AM
oneradten is offline
post #5 of 10 Old 04-09-2006, 12:45 PM
you can degree them with motor in the frame !
http://aceperformance.com/
41 Land Speed record's 650 750 1000 1350 1650 2000 3000 3001+cc classes 236.96 MPH
Winner & fastest N.A. bikes of Texas Mile shootout N.A. and Nitrous class with NO NOS on bike.
223.33 MPH all motor Busa.
203 + MPH 2016 ZX10R
THE ICE MAN is offline
post #6 of 10 Old 04-09-2006, 08:19 PM Thread Starter
ninja3030's Avatar
Thanks for the info! I finally got it. Everything is cleaned and ready to install, probably tomorrow.
post #7 of 10 Old 04-09-2006, 09:16 PM
10 speed's Avatar
Originally Posted by title
Problem romoving head.
uhhh never had that problem. always trying to get Head!
10 speed is offline
post #8 of 10 Old 04-10-2006, 09:03 AM
there is maybe 9 bolts now preventing you from removing the engine so pull it and degree the cams. I had to use the rubber mallet to remove mine, the old gasket was such a pain to clean off, i think it took me over 4 hours to get it clean.
BNninja is offline
post #9 of 10 Old 04-10-2006, 05:59 PM Thread Starter
ninja3030's Avatar
I was lucky for the cleaning, I think it was less than an hour !
post #10 of 10 Old 04-12-2006, 01:15 PM
Keep in mind that when yur degreeing the cams the pointer angle needs to be Sq to the top of the bucket. It's a PITA to get it perfect but you'll find that when it's off the reading don't repeat well and the more it's off the more compounded this situation is. Play around with your set up and you'll find that .001 lift difference makes a BIG difference on the wheel. ANY difference on the wheel changes the outcome ALOT! Therefore doing this in the frame isn't something wise
Gunner is offline
Head Gasket?????? SP8 Performance and Tech 13 10-26-2005 10:35 PM
Star Racing head updated (Dyno) rotts4u Performance and Tech 11 10-26-2005 06:32 AM
Star Racing head work on ZX-10 rotts4u Performance and Tech 39 09-21-2005 12:33 PM
Does this sound like a generator problem?? po boy Performance and Tech 22 08-24-2005 08:22 AM
Gasket and Cam Install BNninja How To... 42 04-08-2005 09:55 AM
