Problem with new exhast - Kawasaki ZX-10R.net
post #1 of 8 Old 11-03-2007, 01:10 AM Thread Starter
I just got my bike back from the shop. I had a new Aprovovick race full system. I also had a valve job and added a BMC race filter. I hauled the bike home and right away I noticed that it was vibrating more than normal. The Vibrating started at about 4000 rpm. The shop is closed for the weekend and doesn't open again until next Tuesday. My questions is should the new exhaust be causing this. I had the bike Dynod and called them afterwards telling them it was vibrating the guy said he didn't notice anything I checked all the bolts took the tank off and checked the air box and can't find the noise or source of the vibration. I was planning on doing a track day this weekend should I go ahead and do it or wait and take the bike back on Tuesday. Is this normall for the full race system. A friend of mine thought the valves may sound lose. Any help would be apreciated. Thank you
Travis Lutter
travis lutter is offline
post #2 of 8 Old 11-03-2007, 02:20 AM
phastone's Avatar
I think that's a common problem with the Aprovovick systems.
phastone is offline
post #3 of 8 Old 11-03-2007, 10:31 AM
Images: 9
sometimes when changing to an aftermarket exhaust it vibrates more than when the stock system was in place.i think it's mostly because of the rubber washers where the mufflers attach to the subframe. and also the weight of the stock system does dampen some vibration.
livharder is offline
post #4 of 8 Old 11-03-2007, 11:50 AM
russell's Avatar
i have no idea WHY it does this but my bike vibrates like a mug and i have the yosh rs-5
russell is offline
post #5 of 8 Old 11-03-2007, 01:51 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
think it may be normal after my exhaust she vibrated, but i dont notiice it now
06blackpearl is offline
post #6 of 8 Old 11-03-2007, 07:48 PM
I have a Akra on my 06 and it has a bzzz around 4-4500. Was much worst with the Boz in prior.
I would suspect you are fine as there is little to go wrong when bolting on a exhaust if the mechanic is even okay.
As for valves they do not make noise on modern bikes.
06450F is offline
post #7 of 8 Old 11-03-2007, 08:07 PM
jimbob8915's Avatar
Does the bike feel better in the power department?
jimbob8915 is offline
post #8 of 8 Old 11-04-2007, 07:09 PM Thread Starter
Power is definitly improved rode it a Motorsport Ranch today. Crazy power (I think) Wheeling tucked down the straight 125 plus indicated third gear (short shifted it to try to keep the front down) great fun. Thank you to everybody for there help. Travis Lutter
for sale akro hex exhast and 8in over swing arm sweetride10r Parts, Gear and Accessories 15 10-24-2007 01:57 PM
PC III problem ??? HELP ninja_12r2000 Performance and Tech 12 05-29-2007 10:27 AM
FI problem Funaru Performance and Tech 1 03-30-2007 03:01 PM
bit of a problem fastburnzx-10 Performance and Tech 24 08-25-2006 06:34 PM
PC problem jstwkd1 The Out House 2 04-21-2006 05:32 PM
