PowercommanderIII Mapping - Kawasaki ZX-10R.net
post #1 of 5 Old 07-11-2010, 07:12 PM Thread Starter
I recently purchased a 2006 ZX-10R with Yoshimura pipes. Im guessing they are slip ons. My question is, the mapping in the powercommander is for two brothers Vale bolt on mufflers. I looked for mapping for the yosh but could only find one that had "baffels removed". Can anyone tell me if there is some way of finding out what I should be using? I have saved what was on there and could try the other to see what happend
dstanobi is offline
post #2 of 5 Old 07-12-2010, 03:20 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
You can try the yosh map mentioned or just call dynojet and tell them your setup...they will look up and give you a compatible map for what you're running, it's at least a good place to start if you've never messed with the tuning and/or adjusting the maps yourself.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #3 of 5 Old 07-12-2010, 04:30 PM
Mladinracer's Avatar
Originally Posted by tmy10er View Post
you can try the yosh map mentioned or just call dynojet and tell them your setup...they will look up and give you a compatible map for what you're running, it's at least a good place to start if you've never messed with the tuning and/or adjusting the maps yourself.
Mladinracer is offline
post #4 of 5 Old 07-14-2010, 08:38 PM Thread Starter
Thanks,
She runs like a top as it is, can it get any better???
dstanobi is offline
post #5 of 5 Old 07-14-2010, 09:00 PM
Supercharged Mod
Slip on mufflers differ very little from one to the other. It's unlikely that you would notice any difference at all, particularly if it runs well the way it is right now. I'd leave well enough alone unless there is a pressing reason to change it.
GoFaster is offline
06 PC III USB mapping for Boz? SAkI The ZX-10R 0 04-19-2008 08:39 PM
Need Boz B2 mapping for my o6... SAkI Performance and Tech 2 03-18-2008 05:17 PM
mapping fbmbks Performance and Tech 1 09-26-2007 01:26 PM
nos & mapping ? hccaamps Performance and Tech 8 04-25-2007 08:52 PM
PC III mapping Older Guy Performance and Tech 54 12-26-2004 09:30 AM
