PowerCommander map question - Kawasaki ZX-10R.net
post #1 of 12 Old 01-16-2010, 08:30 AM Thread Starter
edouble's Avatar
I have a 2006 10R with an HP slip on with an Arrow cat eliminator pipe with factory Ti head pipes. On the intake side a have a BMC filter as well as Ivan's block off plates.
I am currently using a custom map that was tuned for my bike when I had a full LeoVince system.
On the PowerCommander website they have a map for a European 10R with an HP slip on, cat eliminator, factory head pipes with aftermarket filter. Exactly what I have! But it says that O2 eliminators were used for the European model. I do not have O2 sensors so no need for the eliminators.
Do you think this map will work well with my bike even though I do not have O2 sensors and it was tuned on a European bike?
edouble is offline
post #2 of 12 Old 01-16-2010, 01:04 PM Thread Starter
edouble's Avatar
Any comments?
edouble is offline
post #3 of 12 Old 01-16-2010, 01:12 PM
beenthere's Avatar
Euro bikes have different stock maps than US bikes. Although the aftermarket stuff you have is the same considering the Euro dyno tune was built on a different baseline it could be apples vs. oranges
beenthere is offline
post #4 of 12 Old 01-16-2010, 01:47 PM Thread Starter
edouble's Avatar
I was thinking the same
edouble is offline
post #5 of 12 Old 01-24-2010, 09:16 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
Spend the 300 have it made for "YOUR" bike and post it on the site..Then again chk here on this site to see whats close to your set up..pc maps have their own thread here somewhere
craig_sez is offline
post #6 of 12 Old 02-04-2010, 03:54 PM
Johns04ZX10R's Avatar
I am fortunate that a good friend of mine owns a dyno. We spent some time with my 04 ZX10 and tried several different "off-the-shelf" maps from teh powercommander website.
My bike has a muzzy slip-on, BMC air filter, secondaries removed, air injection blocked, and exhaust valve disabled. All stock otherwise.
We found that the PC map which was designated for an all stock bike (stock exhaust and stock air filter) gave us the best AFR (12.8:1) and the smoothest power curve.
The PC map which was designated for a slip-on and BMC filter was terrible. It yielded a very rich WOT AFR, and was way too lean at part throttle. The bike did not run as well with their recommended map.
Just some food for thought, and more reason to get a real dyno tune.
Johns04ZX10R is offline
post #7 of 12 Old 02-04-2010, 05:44 PM Thread Starter
edouble's Avatar
Interesting. I take it that he had a "sniffer" hooked up to your exhaust outlet or do you have O2 sensors?
edouble is offline
post #8 of 12 Old 02-05-2010, 10:42 AM
Yes the dyno is equipped with a wideband O2 sensor and tach sensor input so that it can measure HP, Torque, and AFR
post #9 of 12 Old 02-05-2010, 02:58 PM Thread Starter
edouble's Avatar
I would love to find a shop around here (Northern PA) that has that capability
edouble is offline
post #10 of 12 Old 02-05-2010, 04:03 PM
beenthere's Avatar
Download a Powercommander.com map with similar mods as your bike that was based on a US import map table. You might find that it works pretty good for you. A strange thing happened on the way to the dyno....after putting exhaust systems on many four cylinder sport bikes and then trying to tune the PCs without a dyno (it was when the PCs first came out and we had no dyno access) we had to experiment with maps using what was available from Dyno Jet and some common sense adjustments. We found that reguardless of what name brand exhaust we were using the Akropovic map seemed to work best and that not only crossed over to different exhausts but also to different bike brands. One of the few exeptions was a GSXR 750 with a Muzzy pipe, it liked the Muzzy dedicated map.
PowerCommander Multi-hub Wiring Question afskypilot Performance and Tech 7 08-25-2009 08:21 PM
i need a map for a powercommander 06 zx10r, atre and two brothers slip on single exha Skeez1983 Performance and Tech 26 11-04-2007 03:39 PM
06 Slip-on Map Question T3MPO Performance and Tech 2 07-23-2007 09:06 PM
Map question? doodle Welcome Newbies! 8 06-12-2007 01:27 PM
PC map question CBRE Performance and Tech 1 06-03-2006 06:07 PM
