Powercommander 5 and QEM. Help needed. - Kawasaki ZX-10R.net
post #1 of 3 Old 05-15-2011, 02:44 PM Thread Starter
Hello.
Installed recently PCV and QEM. Problem is that the Quickshifter is not working at all. I tried solve the problem with updating everything: Latest software, firmware and quickshifter update utility. Nothing. No success.
Settings are right, switch type is right. At last i tried to connect the wires from shiftrod sensor directly to PCV connectors #4 and#5. That made the quickshifter able to work as if normal.
After that i tested for continuity the disconnected blue and green wires from QEM. There is continuity between the two blue wires, but not continuity between the green ones. I assume that the problem is in the QEM wiring.
Does anyone have a QEM on hand? I would like to know should there be continuity between the two blue and the two green wires.
mattus is offline
post #2 of 3 Old 05-15-2011, 04:06 PM
cvzx09's Avatar
Images: 7
Originally Posted by mattus View Post
Hello.
do u have ur kill times set for each gear? mine wouldnt work bc i never set up my gear position on my power commander. i set my qs to one kill time for each gear and now it works fine.
Vance and Hines CSone/ Akra link pipe/ Power Commander V/ Dynojet Expansion Module/ Dynojet Quickshifter/ Healtech Xtre/ K&N filter/ 520 Kit -1 Front +1 Rear With EK Green Chain/ Zero Gravity Double Bubble/ Greggs Mirror Block Plates with Signals/ CRG Bar End Mirror/ SS Fender Eliminator/ 6000k Bulbs/ Led Running Lights
cvzx09 is offline
post #3 of 3 Old 05-16-2011, 08:57 AM Thread Starter
I didnīt set gearposition input to PCV. Instead, selected "single time" at settings. No gear dependent. Also did set killtime at 70ms, QS operating rpm above 1000, so i could hear if there is cutouts when running the bike on paddockstand and doing upshifts.
As i told previously, there is cutouts when the QEM is disconnected and the shiftrodsensors wires are connected to PCV.
Is the problem in the QEM, dunno.
mattus is offline
Gen 1: Powercommander 3 usb fs seanc520 Parts, Gear and Accessories 10 04-27-2011 09:26 AM
1st gen vs 2nd gen powercommander Racejunkie05 Performance and Tech 1 12-29-2010 10:25 AM
06-07 Powercommander photodigm1 Parts, Gear and Accessories 3 12-24-2010 06:17 AM
powercommander DANGER10R Parts, Gear and Accessories 5 03-07-2006 10:50 AM
Powercommander calhounzx10 Parts, Gear and Accessories 7 07-19-2005 12:07 AM
