Power Commnader Software Values? - Kawasaki ZX-10R.net
post #1 of 2 Old 07-23-2007, 10:09 AM Thread Starter
La Flama Blanca
9R to 10R's Avatar
Images: 102
How much fuel (- or +) does each point indicate on the PCIII software indicate? Is it a percentage measurement or what? I see numbers on your average map all the way from -20 to + 20, I find it hard to believe that you are taking out as much as 20% or adding 20% at any given rev or throttle %.
The reason I ask this is I took a standard evoII map and ran it for a week, bike seemed to be running a little rich, but the powerband felt fine, no holes or anything, but I was getting a little more black smoke and strong fuel smell coming from the muffler than I would like to see. So I took the Standard map and changed it by -2 across the board, every value, even the ones that were 0 I took 2 points off of. I have only rode the bike to work since then, and it seems to be running better actually, not as much popping on decel and the smoke looks to have went away, you can still smell a little fuel smell but it seems better.
I know dyno tuning is the only way to get your bike tuned proper or even a wide band would be a great help, but this is all I got for now, so tell me anyone, how much fuel did I actually take out across the board, leaning out the map 2 points across the board?
9R to 10R is offline
post #2 of 2 Old 07-23-2007, 10:42 AM
Supercharged Mod
It is meant to be a percentage. I don't know how accurate it is.
You're not the first to find that a lot of those "standard" maps are way too rich at part load.
GoFaster is offline
TPS settings on Power Commander software 9R to 10R Performance and Tech 4 07-23-2007 11:57 AM
Power Commander? +/- values? fun2fly Performance and Tech 3 01-16-2007 09:07 PM
Software For Power Commander Bar Mount Quick Shift Ninja Dude The ZX-10R 0 05-20-2006 12:06 AM
cylinder trim values oneradten Performance and Tech 9 04-06-2006 10:48 AM
Help! Torque values. swjohnsey The ZX-10R 4 05-16-2005 11:47 AM
