Power commander v ex California model - Kawasaki ZX-10R.net
post #1 of 8 Old 03-28-2018, 10:15 PM Thread Starter
Fast4Life's Avatar
Does anyone know if you can change software on one to make it a normal power commander? Guy wants $100 with a werkes slip on that has a ding from I’m guessing him going down.high temp powder coat or something will take care of the ding lol. Also I’m under the assumption that gen 2/3 interchange power commanders.
Fast4Life is offline
post #2 of 8 Old 03-29-2018, 05:49 AM
Victors's Avatar
Nope
2013 10R
2007 650R
2016 10R
Victors is offline
post #3 of 8 Old 03-29-2018, 07:42 AM
GreenOne's Avatar
Regarding gen 2/3, you can use a gen 3 pcv on your gen 2. I am. The main difference, which doesn`t matter, is a hard-coded model number meaning you can not load a predefined gen 2 pcv map in the gen 3 unit directly. (without copying via excel or similar)
I`m just in for the ride
GreenOne is offline
post #4 of 8 Old 03-29-2018, 08:15 AM Thread Starter
Fast4Life's Avatar
Well I won’t really need a predefined map I suppose. Secondaries removed, 45mm headgasket, gen 1 race cam, custom made exhaust from boz bros race header etc. and I saw guys converting maps over. Is the California model worth a damn to buy that cheap?
post #5 of 8 Old 03-29-2018, 09:24 AM
GreenOne's Avatar
Yes, you need a custom map. Don`t know the exact restrictions in the ex version but I think the lower rpm/throttle position part of the map is not editable. I would go with something else, even if its cheap.
GreenOne is offline
post #6 of 8 Old 03-29-2018, 09:43 AM Thread Starter
Fast4Life's Avatar
That’s what I was thinking as well. It’s under 4K and less then 15%throttle that is undesirable. I currently have a LP Dynatek Fuel controller which has 12 different maps and 20% fuel control low mid and high rpm adjustable potentiometers. All in all does the same as a power commander but to piggyback the signal and change it in 250rpm increments, power commander can fine tune better.
post #7 of 8 Old 03-29-2018, 11:40 AM Thread Starter
Fast4Life's Avatar
The picture dude posted of it being an ex model was taken off internet. This is what he just sent me, it’s a normal PCv correct?
post #8 of 8 Old 03-29-2018, 12:49 PM
Victors's Avatar
Have him give you the model number. That will tell you.
2013 10R
2007 650R
2016 10R
Victors is offline
California emissions model? greengrimlin636 The ZX-10R 8 12-17-2016 11:49 PM
Gen 4: california model/evap canister removal 504boy The ZX-10R 1 06-06-2015 08:39 AM
Dynojet California ARB Approved Power Commander III USB-EX2008 Kawasaki ZX-10R jdmshawn eBay & Auction Links 0 12-09-2013 05:24 PM
California Model broken arrow Performance and Tech 2 02-15-2010 10:19 PM
California Model rossifumi The ZX-10R 7 01-21-2009 09:31 PM
