Gen 4: 2011-2015 power commander V or.....? - Kawasaki ZX-10R.net
post #1 of 15 Old 03-31-2013, 10:43 PM Thread Starter
zcar14's Avatar
My buddy has a zx14 and was told that a pcv was a waste of money because it didn't add much hp and in some cases even lost hp. Does anynody have any good/bad experiences with a pcv or any suggestions? Currently the bike has m4 street slayer slip on, ivans wire mod, -1+2 sprockets, and maybe a new air filter if needed for noticeable performance gains. (Yes or no on air filter?)
Thanks for any input guys. Ride safe.
Engineering school blows.
zcar14 is offline
post #2 of 15 Old 04-01-2013, 07:37 AM
SkyDork's Avatar
The only way to get power out of a PCV or similar is to have it custom tuned. Not a waste of money, but not the first mod I'd be doing either. The ECU reflash will be the best money spent. But you'll likely still need the PCV to get the fueling correct. A PCV alone or using a downloaded map is not likely to be of any benefit.
#WordCrimes
SkyDork is offline
post #3 of 15 Old 04-01-2013, 11:09 AM
BOOSTED's Avatar
It's definitely all you need after you get a flash or do the wire mod. I have the Bazzaz ZFI with a quick shifter and trying to fit that unit in a GEN 4 ABS bike is a nightmare. The unit is so much bigger than a PCV. Also the PCV allows for 250rpm tuning increments where as others are 500rpm or higher. Unless you plan on spraying or modding the bike to where you need to use both sets of injectors the PCV is a great unit, it just has to be tuned properly as SkyDork mentioned.
2016 Ninja H2 - CANADAS Fastest 1/4 - 8.34 at 169mph - 208.4mph in the mile. Brocks Performance Stage 2 Package, MC Cycle works Intercooler, Full Polished Slash-Cut Exhaust, DNA Filter, PC5, Brocks Lowering Links, Brocks Front Strap Kit, BST Rim, Adams Performance Swingarm 7-11", Zero Gravity Corsa Windscreen, Evotech Radiator Guard, Evotech Fork Sliders, Yoshimura Tail Tidy
2011 ZX10R - SOLD
BOOSTED is offline
post #4 of 15 Old 04-01-2013, 12:23 PM
BlkCasper's Avatar
I had one installed om my 2012 ZX14 with two brothers slip on. I only gained 10hp and 5 ft lbs tq and got 300 more rpm with a custom tune. But it is soo much smother and plulls like mad from any rpm. Haven't done the ecu flash yet.
BlkCasper is offline
post #5 of 15 Old 04-01-2013, 01:53 PM
Post Whore
-Op-'s Avatar
I got better gas mileage on my Gen 1 after I started to datalog and tune with my PCV/WB2 setup. Bike also is feeling smoother.
-Op- is offline
post #6 of 15 Old 04-01-2013, 02:39 PM Thread Starter
zcar14's Avatar
So if i did the wire mod, i wont need an ecu reflash? I think i could do the tuning myself but i thought pcv was fairly necessary if you add a pipe and want decent power. I'm shooting for as close to 200hp as possible eventually.
zcar14 is offline
post #7 of 15 Old 04-01-2013, 03:02 PM
mdallas's Avatar
If you r looking for 200rwhp then u r going the wrong direction. Email
Garth. I have flash, full graves, BMC, block offs. Retuned flash.
Getting 187.4 rwhp corrected. 195.75 uncorrected.
U have a long way to go.
U will need head work and thinner gasket for sure. Pcv with a good tune with reflash for extra rpms
2011 ZX10R Graves Full, BMC, block-off plates, MotionPro Rev2, 41t rear, Ohlins TTX, rear link, Pazzo shorties, Woolich tuned.
mdallas is offline
post #8 of 15 Old 04-01-2013, 05:41 PM
mustangdame's Avatar
If you're in need of a pc5 I have one for sale off my gen 4.....190 shipped.
mustangdame is offline
post #9 of 15 Old 04-01-2013, 05:47 PM Thread Starter
zcar14's Avatar
I may take you up on that. And ya I know I cant get 200 with just boltons but I want to maximize the hp with just boltons for now. Whats the scoop on block off plates? I see that a lot of people have them and I read up a little on them but I'm not sure on all the details. I'd like to have every hp increasing bolt on possible for now and I was gonna look at engine work once my friend graduates from his motorcycle mechanic school.
zcar14 is offline
post #10 of 15 Old 04-02-2013, 09:32 AM
OK just let me know. I hear block off plates help keep your air/fuel rate the same after tuning. (Don't quote me on that)
Tags
air filter, exhaust, pcv, power commander, zx10r
Gen 2: which power commander ????? chucks ss Performance and Tech 7 10-10-2011 06:47 AM
Any power commander? scott22neale The ZX-10R 6 10-01-2011 10:06 AM
04-05 power commander DareDevil Parts, Gear and Accessories 7 06-07-2008 08:02 PM
power commander ?'s 07_ZX10 Performance and Tech 2 04-18-2008 02:21 AM
Power Commander 10R Performance and Tech 8 02-19-2006 04:10 PM
