Power Commander question - Kawasaki ZX-10R.net
post #1 of 5 Old 04-10-2008, 12:48 PM Thread Starter
morefire's Avatar
Ok, I just recieved my power commander III and BMC Race filter. The person i was going to buy a full Akra system from changed their mind, so I have to wait about another month to order my brand new Akrapovic Evo system.
Question: Should I install the power commander and filter on an otherwise bone stock bike? until I get the Akra later.
morefire is offline
post #2 of 5 Old 04-10-2008, 01:43 PM
ducatiryder89's Avatar
Images: 21
I'd do it all at once. If you have the money might as well throw Factory Pro V-Stacks and change the plugs (if your at 7500 miles). Maybe even the Race Intake Cam. I'd do it all at once. Saves time and money in the long run.
ducatiryder89 is offline
post #3 of 5 Old 04-10-2008, 01:48 PM Thread Starter
morefire's Avatar
Actually, I just realized something..... I ordered it pre programed for the Akra Evo system so not sure if the bike would run right.
Im installing everything myself anyway, so i dont mind doing it if it would make some gain. Also got my 16t and race filter
morefire is offline
post #4 of 5 Old 04-10-2008, 02:12 PM
Images: 21
All that pre programmed gimick is they download a generic map onto the PCIII. That's about it. Not the same as a custom tune.
post #5 of 5 Old 04-10-2008, 02:27 PM
Green's Avatar
With your laptop, you can save a copy of the map that is on it (or redownload it from Dynojet). I'd install it and run a zero map for now, then get a custom map when you get the exhaust on it. You can always put the crappy generic (preprogrammed) map back on it later. It's really easy to load programs into them.
The zero map will leave your a/f ratio as is (stock).
Green is offline
power commander question laughrun Performance and Tech 7 11-24-2007 02:51 PM
Power Commander USB question jimbob8915 Performance and Tech 4 10-25-2007 06:35 PM
power commander question rojapar Performance and Tech 14 09-10-2006 05:33 PM
power commander question Kevy 10 The ZX-10R 4 05-17-2005 04:27 AM
Power Commander USB question NWZX10 Performance and Tech 7 10-26-2004 12:41 PM
