power commander not guilty - Kawasaki ZX-10R.net
post #1 of 10 Old 09-03-2006, 11:32 PM Thread Starter
sorry fellow's my power commander was not the problem with my ten. it tops out at 136 and at this point i do not understand what happening.
pec2903 is offline
post #2 of 10 Old 09-04-2006, 12:45 AM
Clutch slipping? Is it redline in 6th or will it not pull at all. You should be able to hit about 136 at the top of third gear (depending on gearing and speedo calibration).
speedfreak is offline
post #3 of 10 Old 09-04-2006, 12:57 AM Thread Starter
bike has 25,000 miles on it. 6 weeks ago it would top out according to speedo 181 mph. clutch not slipping at all, bike will just not rev. at higher rpms. i ran it threw the gears and rolled on in 6th and will not go past 136mph. rpms will not climb past 10,000 - 10,500. the higher the rpm the more power is lost. i took out power commander, tre and no change. fuel pump is very loud when key is turned on but fuel pressure checked out totally fine. valves are in spec. sparks plugs look real good. i just don't know but the problem started all the sudden. bike does not smoke nor use oil. will have compression checked next.
pec2903 is offline
post #4 of 10 Old 09-04-2006, 01:05 AM
blackisfaster's Avatar
Have no idea, but do know it will not be a compression issue. You can bet it will have someting to do with ECU though. Save yourself some time and frustration and take to shop to do diagnosis. Squelership shouldn't charge (much) for this. Good luck. Peace
blackisfaster is offline
post #5 of 10 Old 09-04-2006, 01:43 AM
Newfie Bullet
craig_sez's Avatar
Images: 34
Hows the air filter???Plugs breakin down ???How much did ya eat for dinner??lol...Kidden on the dinner part..lol
craig_sez is offline
post #6 of 10 Old 09-04-2006, 12:29 PM
bonz's Avatar
Did you recently do an oil change? Another member filled his up to much and was losing considerable power, drained and filled to proper level and was back to normal??????????
bonz is offline
post #7 of 10 Old 09-04-2006, 01:26 PM
Post Whore
i can hit 189 in 6th at about 9,900 - 10,000 rpm
Nick.INF is offline
post #8 of 10 Old 09-04-2006, 01:26 PM
Post Whore
and it still feels like it picks up speed
Nick.INF is offline
post #9 of 10 Old 09-04-2006, 03:07 PM
Post Whore
Older Guy's Avatar
Check your fuel pump?
Older Guy is offline
post #10 of 10 Old 09-04-2006, 04:40 PM
RickRoush03's Avatar
why dont you unplug the battery and let it sit a bit to "reset" itself, i know cars do this with teh ecu and it has to "relearn" the driving style. just a thought. maybe even your coil packs? maybe a weak battery?
RickRoush03 is offline
About Power Commander RaZXiel The ZX-10R 1 05-14-2006 10:48 PM
Power Commander 10R Performance and Tech 8 02-19-2006 05:10 PM
Power commander mad-kaw Performance and Tech 1 04-13-2005 09:44 PM
FS: power commander USB trackaddict Parts, Gear and Accessories 9 01-24-2005 10:39 PM
MPG WITH POWER COMMANDER MAVRIK The ZX-10R 7 07-25-2004 12:42 AM
