power commander ignition module??? - Kawasaki ZX-10R.net
post #1 of 5 Old 06-17-2010, 07:07 AM Thread Starter
pj168rwhp's Avatar
What does everyone think and does anyone have it fitted to there bike.
pj168rwhp is offline
post #2 of 5 Old 06-17-2010, 11:31 AM
dirt ninja's Avatar
Images: 9
Its good for another 2 ponies.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #3 of 5 Old 06-17-2010, 02:47 PM
Black_Beauty's Avatar
At least that! you can also get the Rev X-tend with it which allows you to add another 500 RPM's to your power curve. You can also play with the ignition timing and fuel for each cylinder. It all depends on you and what you are trying to do with you 10. If your doing it cause you think it might get you more power save yourself the money and do something else with it. After doing the stuff I have done to my 10 I would have gone a little different about it if I could do it again. The secondary's would have come off right away and added a K&N. Then I would have added Rifleman's 1/5th insert. You can also move your stock stacks around for more power. Then a 16T front sprocket. Thats is only a 1/3 of what an ignition module cost and these mods would make you feel like you added 30 RWHP. I had all of my mods before I got my 1/5th and all I can say is I'm stupid for not doing it sooner. It makes a world of difference. Just make sure your hanging on!
Don't get caught up in the mind set that you need everything out there that can get you more power. A lot of people get that way, I'm guilty of that. In stock trim the 10 can put down 150RWHP depending on gen. The only other mods I will be doing will be stopping power and better suspenion. Spend away there! I'll get off of my soap box now.
"a symbol of excellence, a badge of courage, a mark of distinction in the fight for freedom." John F. Kennedy
HP: 158.9 TQ: 76.7
Ti-Force Full Titanium Exhaust, Factory Pro Velocity Stacks, Power Commander USB III, Ignition Module, K&N Air Filter, Riflemans 1/5th, Ping Racing Double Bubble Wind Screen Light Smoke, Goodridge SS Fr/Rr Lines, 6000K HID Kit, 6000K Led Running Lights, Wind Screen and Fairing Black Bolt Kit, and ...More to come!
Black_Beauty is offline
post #4 of 5 Old 06-17-2010, 03:30 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
I've been thinking about getting one as well......good thread
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #5 of 5 Old 06-17-2010, 05:53 PM
dirt ninja's Avatar
Images: 9
been there and done that.
06/07 power commander usb and ignition module 208868 Parts, Gear and Accessories 9 04-01-2009 05:46 PM
04 05 Power Commander / Ignition Module Rspec99 Parts, Gear and Accessories 2 12-08-2008 04:19 AM
Power Commander Ignition Module wattgn Performance and Tech 2 11-18-2006 09:07 PM
Power Commander Ignition Module ?? WRECKSHOP The ZX-10R 4 07-02-2006 06:56 PM
Anyone try out the new dynojet/power commander ignition module? garth285 Performance and Tech 9 05-24-2006 08:15 PM
