Gen 1: 2004-2005 power commander help - Kawasaki ZX-10R.net
post #1 of 7 Old 06-12-2012, 01:10 PM Thread Starter
DixonCiderBuT's Avatar
Just bought a used power commander looks like everything was there
How about to you guys does everything seem to be intact?
what is the little short 3 inch double plug wires for?
DixonCiderBuT is offline
post #2 of 7 Old 06-12-2012, 01:15 PM
nakedinseattle's Avatar
small white plugs into tps (front left under air box), big plugs are for fuel rail (bottom right air box), little guy goes to battery. done deal. and in case pictures are your thing, look at link, explains it perfectly. also, when you plug it all in, turn the key to on position, make sure green lights come on pc3, should be all the way at the bottom. then, turn bike on, rev throttle a little bit, make sure lights move up and down with throttle correctly. you need the install software for your laptop, load it up, zero out the map and then go to a dyno tuner to have it done properly. maps need to be custom made for each bike.
http://www.powercommander.com/downlo...eng212-411.pdf
nakedinseattle is offline
post #3 of 7 Old 06-12-2012, 01:21 PM Thread Starter
thanks I understood most of that before buying, Just wanted to make sure most wasnt missing. Youve been a big help on the link thanks.
post #4 of 7 Old 06-12-2012, 01:39 PM Thread Starter
if anyone else is interested i believe there is another one on ebay going for 190 !
post #5 of 7 Old 06-12-2012, 01:58 PM
Heavyweight's Avatar
Hey dixon can you send a link
Heavyweight is offline
post #6 of 7 Old 06-12-2012, 02:07 PM
http://lmgtfy.com/?q=ebay+power+commander+zx10r
i'm all about the links today
post #7 of 7 Old 06-12-2012, 03:37 PM Thread Starter
Sorry I left out for work look around on ebay there was 1 other one just looked more used email them your price they might drop it for you
Power commander v booboo_26 Strip 1 02-17-2009 07:28 PM
power commander map???? vataren The ZX-10R 2 12-27-2008 08:08 AM
Power Commander CowTownZX-10R Parts, Gear and Accessories 2 07-13-2006 10:08 AM
FS: New zx-10r power commander strongbear0 Parts, Gear and Accessories 9 06-21-2006 07:17 AM
The Best POWER COMMANDER CoolTD Performance and Tech 11 06-19-2006 07:40 PM
