Power Commander ??? - Kawasaki ZX-10R.net
post #1 of 10 Old 05-23-2007, 07:56 AM Thread Starter
1bad10r's Avatar
Power Commander ???
The three buttons on the face of it...I want to up the fuel one notch on it. I know I hold down all 3 buttons, turn on bike and let go. I tap the high button and it goes up one notch. I let it sit there for a sec or so and it drops to running position. I shut off the bike and hold the buttons down again, but instead if it being up the one notch....it's back on 0 or in the middle...where it was before I did the last change. Do I have to do something to lock in the +1 notch on the fuel??
-1 front....+1 back, speedohealed*
Akrapovic carbon bolt-ons
Gutted Cat Converter
No secondaries
Ivans TRE
PCIII usb
1bad10r is offline
post #2 of 10 Old 05-23-2007, 09:14 AM
blackisfaster's Avatar
I could no tget it to work either. Just get a laptop and it is a breeze. You can change fuel ratio at all RPM ranges.
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
2006 ZX10R (Black)
blackisfaster is offline
post #3 of 10 Old 05-23-2007, 09:27 AM
Let me ask a question, after power commander install bike runs alot smoother. My only problem is it is harder to crank, takes about 3-4 times to start. After warm up it is great. Do you have the same problem? If so, have you fixed it? DOn't want to fool around to much with map, don't want to pay for dyno right now, until I get full system on. Peace
2006 ZX10R (Black)
post #4 of 10 Old 05-23-2007, 09:58 AM Thread Starter
1bad10r's Avatar
Someone else on here asked me about the way my bike starts. There was no difference for me with or w/out the PC. Starts quick as it did new.
1bad10r is offline
post #5 of 10 Old 05-23-2007, 10:14 AM
Thanks, maybe because I have no mod's. My bike is stock. I am going to reload map. I am using the pre-programmed one. It is for stock. Peace. Get a laptop to address your issue. Sounds like you know what you are doing.
2006 ZX10R (Black)
post #6 of 10 Old 05-23-2007, 10:16 AM Thread Starter
1bad10r's Avatar
No...I have a custom map in my PC....I just want to increase the fuel a lil bit, so what I need to do is done with the buttons on the PC, nothing to do with the map at all.
1bad10r is offline
post #7 of 10 Old 05-23-2007, 11:58 AM
You can adjust at 0 RPM with control center and laptop. I just tried the three button and it worked. I held the three buttons down and plugged in 9Volt battery, went to zero position plus one. I pushed the low button and it went up by one notch, I then held down continuously and it went down. I then waited a couple seconds and it programmed the new setings. It will drop down to the bottom when completed. Hope this helps. By the by, I uploaded the -001 stock map and bike starts like it did before PCIII install. I also went up one notch from zero on the low side. Peace
2006 ZX10R (Black)
post #8 of 10 Old 05-23-2007, 12:21 PM Thread Starter
1bad10r's Avatar
So if I want to increase mid...I hold down all 3, start bike, release, tap mid, then tap high to increase or low to decrease.....and the same for the other ranges?
1bad10r is offline
post #9 of 10 Old 05-23-2007, 01:35 PM
ninja44's Avatar
I have the same issue with the first cold start of the day. I have the PC3 w bolt on Akros and Ivan's map. Maybe it is too rich or too lean off idle?
________
MARIJUANA MEDICAL
ninja44 is offline
post #10 of 10 Old 06-12-2007, 12:41 AM
Newfie Bullet
craig_sez's Avatar
Images: 34
My bike has an idle fluttering,its not steady...been thinkin that i should up all the numbers by one(from 0 rpm to 1200 rpm)any opions??
craig_sez is offline
WTB - Power Commander Holiday10r Wanted: Buy or Trade 3 03-30-2007 07:57 PM
power commander? Wind Draft Vendors deals 2 02-27-2007 11:59 AM
About Power Commander RaZXiel The ZX-10R 1 05-14-2006 09:48 PM
Power Commander 10R Performance and Tech 8 02-19-2006 04:10 PM
Power Commander III RobinT Performance and Tech 1 08-18-2004 07:02 AM
