powder coating wheels - Kawasaki ZX-10R.net
post #1 of 64 Old 10-29-2007, 12:38 PM Thread Starter
russell's Avatar
so i'm getting my wheels powder coated. i have the rear taken off, the sprocket and rotor are remove, but there is a bearing inside the wheel with rubber bushings on each side. after the wheels are powdercoated they will go into an oven that is 425 degrees, do i need to be worried about these bushings? it doesn't seem like they are removable with the tools that i have.
russell is offline
post #2 of 64 Old 10-29-2007, 12:44 PM
FAF
Rent this space
Yes , you will have to remove them, its a little easier than it looks , you may end up damaging the rubber seals though.
You can tap the bearings out if you dont have a puller, by using a 12 inch extension and a hammer and tapping from the opposite end to the bearing.
FAF is offline
post #3 of 64 Old 10-29-2007, 01:08 PM Thread Starter
russell's Avatar
thanks for the info. i may see if this place can remove it for me, i'm buying tires from them so hopefully they can hook it up.
russell is offline
post #4 of 64 Old 10-29-2007, 01:28 PM
fbmbks's Avatar
Send a message via AIM to fbmbks
I would wait to take them out after you get them powder coated so that the powdercoating doesnt get in the bearing race and put new ones in after you get the rims back
fbmbks is offline
post #5 of 64 Old 10-29-2007, 03:00 PM Thread Starter
russell's Avatar
so you're saying take them out after the powder coating but before the oven? i'm just going to mask that part with tape for when he paints over them.
where would i get new bearings? kawasaki dealer?
russell is offline
post #6 of 64 Old 10-29-2007, 03:07 PM
Big Daddy's Avatar
Images: 38
hey heads up fellas!!!
The dust seals and bearings should be removed prior to the powder coating process let alone the baking process. I suspect a good PC will inform you of this as well due to the bearings containing grease/lube that will ooze out in the oven and ruin the job.
Big Daddy is offline
post #7 of 64 Old 10-29-2007, 03:10 PM
Big Daddy's Avatar
Images: 38
REMOVE THE BEARINGS and save yourself a major headache of a fugged up job.
The PC will mask off the areas(rotor, bearing surfaces etc) needed as part of the job.
The bearings can be had from KHI or any reputable bearing retailer once your able to get the bearing part #'s that are stamped in them.
These are the most recent ones i had done.
post #8 of 64 Old 10-29-2007, 03:30 PM Thread Starter
russell's Avatar
quality information, thanks pal.
russell is offline
post #9 of 64 Old 10-29-2007, 03:40 PM
kawiiiiii's Avatar
Images: 19
I had two sets of rims PCed in last few months and I had to remove everything. Powder gets in the bearing housing but not a problem you can clean it up before inserting the bearings. There is no need to get new bearings if you removed them carefully without damaging the bearing seals.
kawiiiiii is offline
post #10 of 64 Old 10-29-2007, 03:43 PM
Big Daddy's Avatar
Images: 38
If a puller is used then most likely no damage will occur but if the caveman method( a 12-14" flat nosed punch & hammer) is used to literally beat on the inner race of the bearing during removal most deffinately replace them.
Powder coating in So CA sonnyboy11 Performance and Tech 3 05-06-2007 02:34 AM
powder coating wheels. A bad thing? volo Performance and Tech 33 10-29-2006 10:36 AM
Powder Coating ??? chad1043 The ZX-10R 17 08-17-2006 01:54 PM
Pros and cons of powder coating wheels maze The Out House 5 01-30-2006 02:18 PM
powder coating the wheels miykl The ZX-10R 25 12-22-2004 03:35 PM
