Please Help With Butterfly Valve Question - Kawasaki ZX-10R.net
post #1 of 7 Old 11-13-2008, 12:21 PM Thread Starter
welds like he has palsy
JP636's Avatar
As I mentioned in a previous post, I've been having problems with my servo motor not opening up the butterfly valve. I went ahead and took off the metal plate that holds the wires. I was told that I could just take that off and the butterfly valve would stay open.
When I took off the rear set and looked, I saw a little metal tab that's on a spring by the mid pipe. It's default position is sprung down. My question is: When it's down is the butterfly valve open? Or when I push it up is the butterfly valve open? I really have no way of taking off the exhaust to see.
I've attached pics so you all can see what I'm talking about. In the second pic you can see it in the down position. In the third pic I'm pushing it up.
Thanks everyone.
Name:	Area Circled.jpg
ID:	81529   Click image for larger version
Name:	Butterfly Valve Area Circled.jpg
ID:	81530   Click image for larger version
Name:	Pushed Up Arrowed.jpg
Originally Posted by green10 View Post
speakers on a zx10 is like shitting in your bathwater!!!
JP636 is offline
post #2 of 7 Old 11-13-2008, 01:27 PM
konichd's Avatar
When I took my exhaust off my 06 I remember it being open by default. The servo motor then "closes" the valve at higher RPM's for emission control.
2006 Kawi ZX-10R "Reverse GP"
www.303cycle.com
konichd is offline
post #3 of 7 Old 11-13-2008, 02:15 PM
Speed Freak
garth285's Avatar
thats correct, if you leave everything off the valve will stay open the servo just closes the valve when the ecu tells it...
garth285 is offline
post #4 of 7 Old 11-13-2008, 03:07 PM
Accountant in training.
Deer Elk's Avatar
Chris
Deer Elk is offline
post #5 of 7 Old 11-13-2008, 03:19 PM Thread Starter
JP636's Avatar
Anyone take their servo off on while using a stock exhaust? Any performance difference?
JP636 is offline
post #6 of 7 Old 11-13-2008, 10:14 PM Thread Starter
JP636's Avatar
Ok I'm bumping this question. I'm trying to get it fixed before the gas goes bad
JP636 is offline
post #7 of 7 Old 11-13-2008, 10:22 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Think you got it backward, it opens the valve at higher RPM's, the noise tests take place in the lower rpms. But if you disconect the cables the valve will spring open.
9R to 10R is offline
Butterfly valve vjhils Performance and Tech 3 12-03-2007 12:29 PM
Question about butterfly valve cables (exhuast) 06Neenja Performance and Tech 0 04-19-2007 06:38 PM
Disabling the butterfly valve ? gixxerich Performance and Tech 31 09-15-2006 02:34 AM
Butterfly Valve pic PLZ! BeepeR Pictures and Videos 23 03-18-2005 11:23 PM
Butterfly Valve pic Please BeepeR Pictures and Videos 5 09-26-2004 11:08 AM
