Please Help!!! 1/5th Throttle Conversion - Kawasaki ZX-10R.net
post #1 of 5 Old 05-09-2007, 10:15 PM Thread Starter
Angry Please Help!!! 1/5th Throttle Conversion
I am trying to put my 1/5th throttle conversion on and just can't get it right. I've done all of the steps and my throttle still hangs up. I've cut the lock rings off and backed it up as far as i could but it doesn't give it enough slack. I have an 06 zx10 which only has one adjustment up top. I noticed in the illustration there were two adjustment but that must be the 04 and 05 model. Just wondering if I need to lengthen the cables, if so how much?
HobieZX10 is offline
post #2 of 5 Old 05-10-2007, 12:17 AM
Stretchy's Avatar
This may sound dumb but it caught me out when i did mine for a few minutes.
Check if your bar end is hanging up the throttle, i managed to pull the grip down and when i released the throttle was hung up on the bar end. Just slipped the grip back a bit and all was solved.
Black and Green 05 ZX10R - Race Bike
Stretchy is offline
post #3 of 5 Old 05-10-2007, 09:31 AM Thread Starter
Thanks for the reply. I'll try that.
post #4 of 5 Old 05-11-2007, 01:45 PM
Twrecks's Avatar
Both cables need to be adjusted. I just did my 04 last night and experienced the same mushy return. Had the air box off and cut the lock ring on by the throttle body, plus had to get pliers on the upper adjuster by the radiator/frame.
Another thing, make sure your insert sets square on the stock cam. I had to dremmel mine a bit so the hooks had sysmetrical cut outs, plus filed flat one side flush. Added a bit o'lith grease and all is fine.
G'luck
Smoke'em if u got'em (tires)
Twrecks is offline
post #5 of 5 Old 05-11-2007, 09:23 PM Thread Starter
Thanks for the advice. I added about an inch to both cables and it works great now without any problems.
What does the 1/5 throttle conversion do? 99vorsi Race and Stunt 11 05-29-2015 02:26 PM
where do you buy the 1/5th throttle conversion konman Performance and Tech 2 08-30-2006 07:56 PM
1/5th throttle conversion binding. The Duke Performance and Tech 3 05-13-2006 06:31 PM
1/5th Throttle Mod and 520 Conversion mach_man_187 Performance and Tech 5 03-12-2006 02:56 PM
1/5th throttle conversion how-to w/ ***pics*** hillcountry10r How To... 1 11-14-2005 12:06 PM
