pistons question - Kawasaki ZX-10R.net
post #1 of 2 Old 08-23-2008, 04:05 PM Thread Starter
bodyglove's Avatar
Images: 15
Send a message via MSN to bodyglove
pistons question
hi any one ever tried stock bore high compresion pistons ?
DISP. 998cc
BORE SIZE 76mm
OVER SIZE std
COMP.RATIO 13.5:1
any feed back ???????
YOUR BIKE MUST BE VERY FAST!!because you were haulin ass when i passed you on my NINJA
bodyglove is offline
post #2 of 2 Old 08-23-2008, 08:13 PM
axo250's Avatar
Send a message via AIM to axo250
I've got JE pistons that are 13.5:1 but not at stock bore. Pistons seem to be doing good. Just be very careful to double check your ring gaps before you put the pistons back in. I have heard of problems with that in the past. Also be sure to put the rings on the right way (they have a top and bottom). Its hard to tell the difference in sides but there is a slight difference just to give you a warning.
"Besides, my ZX-10R eats GSX-Rs for breakfast." -- SportRider Magazine Article
axo250 is offline
gas porting pistons MACHINE Performance and Tech 3 08-04-2008 03:23 PM
JE pistons installed... now how do I run em in? CountDokoo Performance and Tech 8 04-28-2007 07:34 AM
Turbo pistons DethsZX10 Performance and Tech 2 01-14-2007 10:58 AM
Wiseco pistons bluebyyouz Performance and Tech 40 09-19-2006 08:42 PM
Pistons & Cams jburmeister Performance and Tech 17 03-08-2005 02:30 PM
