Pistons & Cams - Kawasaki ZX-10R.net
post #1 of 18 Old 02-27-2005, 10:38 AM Thread Starter
Pistons & Cams
Looking for information on pistons and cams for 04 ZX10R, so if anyone has anything please let me know!!!!!
jburmeister is offline
post #2 of 18 Old 02-27-2005, 10:55 AM
OG Post Whore
stunnerific_harry's Avatar
Send a message via AIM to stunnerific_harry
are you looking for stock or aftermarket?
Kip: Napoleon, don't be jealous that I've been chatting online with babes all day. Besides, we both know that I'm training to be a cage fighter.
Pedro: Yes. I don't understand... they say you're not allowed to have pinatas that look like real people, but in Mexico, we do it all the time.
Pedro: Vote for me, and all your wildest dreams will come true.
stunnerific_harry is offline
post #3 of 18 Old 02-27-2005, 11:01 AM Thread Starter
Aftermarket. Looking into seeing how much I can get without turboing the bike (I still like to do standups :)
post #4 of 18 Old 02-28-2005, 02:14 PM
Supercharged Mod
Have a look at Ivan's Performance (one of the site sponsors). He made a thread about several incremental improvements to achieve about 170 hp and around 82 - 83 lb.ft of torque (but without changing camshafts or pistons).
I have a suspicion that it will be hard to do much more than that without major compromises in other areas and/or without spending HUGE money on it. The stock pistons are already short-skirt, quite light, rather high compression ratio. (Do you really want to be *stuck* with running race fuel only?) The stock cams already have rather long duration (have a look at the cam timing specifications in the shop manual).
The amount of torque that a normally-aspirated gasoline engine can produce is limited by the amount of air and fuel that it can breathe in. The 82 - 83 lb.ft per litre of displacement which Ivan got is at the outer boundaries of what's normally seen. MotoGP bikes are in this same range - they make their power by making that torque at higher revs, and that requires a lot more internal surgery in order to stay together at those higher revs. Even Formula 1 cars are only slightly higher than this.
If what you are starting with is pretty good, usually wild camshafts only move the torque peak to higher revs (but compromise low-end and mid-range). Is that what you really want ... ? ? ?
I'm not bashing the idea, I'm only trying to make sure you're aware of the issues and costs, and you know what you are getting into ...
GoFaster is offline
post #5 of 18 Old 03-01-2005, 12:20 PM
beenthere's Avatar
Pistons if avail. would be from JE or Weisco. Cams if avail from Yosh or WebCam. I believe Attack perf. may now have some 10r motor parts available. Another person who might help, is Kelley Robertson, in Texas. I have lost his ph #(ask for that phone number on the "help me beat pesky" thread) Kelley's conservative motor building philosophy has yielded great motors that don't break. His head work is consistently top notch. Happy motoring!
beenthere is offline
post #6 of 18 Old 03-01-2005, 12:38 PM
beenthere's Avatar
A normally aspirated motor will almost never have the hp potential of a turbo. Don't dispair, your 10r will respond very well to a good pipe, and properly tuned power commander. If in your area you have access to a dyno that has the auto tuning link (dyno jet only-I think) you can produce a map that not only takes into account your choice of pipe, but it will also compensate for production variables that your particular motor may have. Happy motoring.
post #7 of 18 Old 03-01-2005, 02:26 PM
good info....and nice posting
MAVRIK is offline
post #8 of 18 Old 03-05-2005, 04:00 PM
axo250's Avatar
Send a message via AIM to axo250
You could also look at carpenter racing. They are doing a bunch of work with the 10 right now and could probably give you some good places to get em.
axo250 is offline
post #9 of 18 Old 03-07-2005, 07:11 AM
I Thought Carpenter Racing Was Previously Discussed And There Was A Lot Of Mixed Review On Their Quality....
MAVRIK is offline
post #10 of 18 Old 03-07-2005, 11:36 PM
Kawaski is releasing a "race kit" that will have engine parts available. I have talked with a few people about it and the stuff is almost all in the us. They are catalogging it right now and should be available some time next month. I know there are pistons, cams, as well as several other VERY trick pieces.
Top Shelf is offline
Anybody make cams yet sweetride10r Performance and Tech 23 12-31-2004 02:10 AM
Cams 96dragshee Performance and Tech 14 10-30-2004 02:04 PM
