Ping at low revs when accelerating - Kawasaki ZX-10R.net
post #1 of 12 Old 12-05-2005, 05:12 PM Thread Starter
Hi. I've been hearing light pinging at low revs (1,500 - 2,500) when accelerating away from a stop. You can see my mods in my signature. I'm guessing the PCM is too lean at partial-throttle openings at those rpms? When I look at the map it does show negative values at low throttle openings. My map is from Dynojet for a Akra pipe with stock filter. I haven't made any changes to it yet. Any suggestions? I guess I could start by enriching those partial throttle, low rpm values? Can you think of any other reasons for the pinging? Thanks.
Full Akrapovic Evo II Ti w/short can, PCIIIusb w/Quickshifter, Helibars, Scotts Damper reverse mounted, Galfer SS brake lines, ZG DB screen, Clear Alternative flush mounts, CRG shorty levers, CW fender eliminator, Kawasaki solo seat cover, -1 AFAM front w/Speedo Healer, Champ91 frame sliders
05kaw10r is offline
post #2 of 12 Old 12-06-2005, 09:51 AM
busaforhire's Avatar
sounds like your answering all of your own questions.. Yes richening up the low rpm circuits will rectify your situation. I have tried a couple of maps that did the same thing for me as well.
05 lime green. Sato slip-on, pc3usb, bmc race filter.
"when ya lose site of why ya ride then you've lost what really matters"---THE MOTORHEAD
busaforhire is offline
post #3 of 12 Old 12-06-2005, 10:26 AM
Send a message via AIM to lbz34
My 05 is bone stock and it does the same thing.
lbz34 is offline
post #4 of 12 Old 12-06-2005, 12:15 PM
The engine isn't designed to operate a large throttle openins and low rpm. If you are gonna nail it keep the rpm up.
swjohnsey is offline
post #5 of 12 Old 12-06-2005, 01:35 PM
Rspec99's Avatar
Images: 11
What octane rating are you using? Also, is it a cali spec bike?
I have never heard any pinging on my bike and I have similar mods. I only run 94 octane in it.
Rspec99 is offline
post #6 of 12 Old 12-06-2005, 01:44 PM
Mine pings also. After switching fuel I found it only likes Shell
V-power
Eyeonyou is offline
post #7 of 12 Old 12-06-2005, 02:06 PM
Mine never did it bone stock but once I started playing with installing different maps I noticed it instantly with some maps.
post #8 of 12 Old 12-06-2005, 02:25 PM
MIA Post Whore
miykl's Avatar
I've never had any ping and I have my ignition advanced and run midgrade fuel. Sea level may be my savior. As stated above, adjust the map.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #9 of 12 Old 12-06-2005, 05:46 PM
All we have here at the pump is 91 octane. We are at altitude 6000 ft. I usually see cars run a little rich. I would imagine bikes would act similar.
lbz34 is offline
post #10 of 12 Old 12-06-2005, 06:15 PM
Rspec99's Avatar
Images: 11
Hmmm... Interesting, most of my riding is at around sea level, but on my mountain roads rides I have yet to notice any pinging or anything either.
I know it has been mentioned that there might be a tad too much ignition advance down low on 10R's. Maybe the answer to the problem is to pick up up a dynjet ignition module and retard the timing at lower rpms.
Rspec99 is offline
Low Fuel light....when..? voytek The ZX-10R 18 06-23-2004 07:01 PM
