Gen 5: 2016- Performance upgrade - Kawasaki ZX-10R.net
 7Likes
post #1 of 18 Old 01-31-2019, 07:54 PM Thread Starter
Performance upgrade
I recently bought a Brocks performance predator 3/4 exhaust and want to do more, they recommend a ECU flash with a power comander v. Is it worth it getting both or am I wasting money?
threecs774 is offline
post #2 of 18 Old 01-31-2019, 08:00 PM
ddipaola's Avatar
Where do you live?
When in doubt... send it!
ddipaola is offline
post #3 of 18 Old 01-31-2019, 08:01 PM
Formerly CLCRACINGAaron
Neonmarine's Avatar
A PCV is not necessary if the ECU gets a reflash by a shop. Brockís will have a flash for that pipe and it will be safe. A PCV isnít going to add anything.
"You must subsume yourself to the bike"-Casey Stoner
"Thereís a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #4 of 18 Old 01-31-2019, 08:17 PM Thread Starter
I live in pa, Brocks said they went flash without a power commander
post #5 of 18 Old 01-31-2019, 08:18 PM Thread Starter
Sorry, won't flash without a power commander
post #6 of 18 Old 01-31-2019, 08:58 PM
Neonmarine's Avatar
https://brocksperformance.com/brock-...d-us-your-ecu/
Looks like they donít mention that. Might call them...
post #7 of 18 Old 01-31-2019, 09:03 PM Thread Starter
Thanks
post #8 of 18 Old 02-01-2019, 07:09 AM
If your in PA, look up Guhl...
wheelz96 is offline
post #9 of 18 Old 02-01-2019, 07:30 AM
ddipaola's Avatar
Yeah, Don Guhl does good work on the Gen5's... getting on the dyno would be your absolute best bet. You will need some kind of PCV or aftermarket fuel management system to have the bike dyno tuned. That's just what most dyno tuners require. I would get a PCV and get on the dyno then have Guhl flash the updated fuel map into the bike. You can then sell the PCV.
You otherwise do NOT need a PCV for a simple ECU flash, don't believe anyone that tells you otherwise. If you want just an ECU flash and don't want to travel or buy a PCV get with Shnitz, Nicks Performance, or EJR performance. ACE Performance is also really good. Those are going to be the best street tunes out there. And I would say SBU or EDR are going to have the best track tunes.
ddipaola is offline
post #10 of 18 Old 02-01-2019, 05:10 PM
Kawasaki Brad's Avatar
A flash is fine if you never mod again. The PCV allows you to fine tune as you go. Plus you can dual map with the PCV so you can have a fire breathing razors edge track map and then your daily driver with a bit richer AFR.
Flash does some things that can't be done with the PCV like timing retard at the high rpm's and/or raising the rev limiter.
My 2c is get both. Not a waste of money.
Kawasaki Brad is offline
Brake upgrade ! best upgrade so far! Simonvez The ZX-10R 2 07-22-2013 03:55 AM
Performance upgrade questions Moody Mane Performance and Tech 19 01-18-2013 02:43 AM
Power Commander and Air Filter Upgrade??? youngballer The ZX-10R 15 08-26-2004 08:51 PM
PCIII usb upgrade? Ground Zero The ZX-10R 7 07-29-2004 10:23 AM
Squid Upgrade? RedRoger2 The ZX-10R 20 06-18-2004 02:31 PM
