Gen 5: 2016- Performance upgrade - Page 2 - Kawasaki ZX-10R.net
 7Likes
post #11 of 18 Old 02-01-2019, 05:39 PM Thread Starter
Thanks for the comments it helps, I will probably go with both because I want to have options in the future!
threecs774 is offline
post #12 of 18 Old 02-01-2019, 07:09 PM
mpp12's Avatar
let me correct you guys, if the guy that flashes you with woolich, and gives you the password,or simply does not put one on the tune, you can tune the ECU in the dyno..
here there are guys that do nice work tunning... and all the dyno I have done on the gen5, is 10% work on fuel, and 90% on ETVs. this bikes come pretty much good on fuel.
I never recomend piggy backs (PCV or bazzaz).
Neonmarine likes this.
mpp12 is offline
post #13 of 18 Old 02-01-2019, 08:53 PM
I never can understand why a flash is recommended with a PCV for fine tuning or even further tuning vs buy Woolich kit get it with autotune and have the ability to do it yourself. I mean Woolich offers so much more in flexibility and options for now and the future.
On my Gen 4 I can triple map.
If you're going to fine tune with a PCV you're going to need a wideband and some kind of data logging or their AT. PCV AT does great in the mid to high TPS settings, but is garbage in the lower loads.
Show me a person with a tuned afr at idle/low loads with a PCV AT and I'll show you a bike with a shitty tune as the weather changes and bike temperature changes.
Finally, what is the difference between a track tune and a street tune? How would different people/shops tune for this? Other than rider preference in ETV settings(most likely track specific as well and not something most people even would notice)no shop or person could generically do for the masses, what is the difference between them?
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is online now
post #14 of 18 Old 02-01-2019, 11:38 PM
ddipaola's Avatar
As long as you have a big enough pool of data, from multiple tracks, you could fit large group of track riders. SBU's track based flash tune is built off probably hundreds of hours at tracks across the country. With enough splicing and followup testing I'm sure they were able to put something really good together that can meet the needs of the avg track day junkie (they're at least comfortable enough to sell and charge hundreds of dollars for what they've got).
I would think a street tune is more based on straight line dragy/gps data for the ideal 'street racing' scenario lol
When in doubt... send it!
ddipaola is offline
post #15 of 18 Old 02-02-2019, 12:11 AM
thundercoupe9's Avatar
You know that if you don't know anything about this subject, you can just type i don't know.
bun1t, realpsi and rcannon like this.
thundercoupe9 is offline
post #16 of 18 Old 02-02-2019, 06:04 AM
Here would be my differences in tunes. For most people nothing. Max horsepower and best driveability tune or settings are the same regardless of location within a geographic location. I don't want to get into altitudes, atmospheric pressures, humidity, or the fact none of the ECUs truly measure the air mass coming in and are always providing the best guess at fueling. For most people on most days, this is insignificant.
If I was tuning for something where there would be extended time at WOT in 6th gear then I would add fuel up top and might pull a little timing very high in the rpms.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
post #17 of 18 Old 02-02-2019, 10:54 AM
Kawasaki Brad's Avatar
Location: Stony Plain (West of Edmonton, Alberta, Canada)
@real psi
My track tune has a bit of ignition retard and runs on the rich side when pumping C12 and nitrous (drag strip).
My street tune is pump gas with a very crispy ignition. Not scaled at all for gogo juice, and a big bump in the + on 0% throttle to keep the popping down on decel (doughnut munchers are real bitches about loud pipes here in Edmonton).
I've wanted to go down the woolich road for some time but my place of employment has all dynojet brand stuff including software, dyno, and product. Anything else would be an uphill battle. I do like the package deal with woolich though and it sounds like they run a tight ship over there. Just a matter of time before I get to try one of those.
ddipaola likes this.
Kawasaki Brad is offline
post #18 of 18 Old 02-02-2019, 05:46 PM
Originally Posted by threecs774 View Post
I recently bought a Brocks performance predator 3/4 exhaust and want to do more, they recommend a ECU flash with a power comander v. Is it worth it getting both or am I wasting money?
Why would you do both? A flash is all you need. Brocks should be able to supply a flash that works properly with their exhaust.
bbsteinnewyork is offline
Brake upgrade ! best upgrade so far! Simonvez The ZX-10R 2 07-22-2013 03:55 AM
Performance upgrade questions Moody Mane Performance and Tech 19 01-18-2013 02:43 AM
Power Commander and Air Filter Upgrade??? youngballer The ZX-10R 15 08-26-2004 08:51 PM
PCIII usb upgrade? Ground Zero The ZX-10R 7 07-29-2004 10:23 AM
Squid Upgrade? RedRoger2 The ZX-10R 20 06-18-2004 02:31 PM
