penske setup questions - Kawasaki ZX-10R.net
post #1 of 6 Old 07-25-2007, 10:19 PM Thread Starter
nelly250's Avatar
Hey all, im looking for a base setup for my penske to try at the track this weekend. I've got my 8987 set as 4mm over stock length + the 3mm factory shim. I run 190/55 tires. My main concern is getting the highspeed compression somewhat close as I don't have much test and tune time before the races. Im 225lbs in gear and the spring is a 600. Please post up your setups (ie how many clicks, ride height, spring rate ect)
Cheers
04zx10r - Yosh rs3 s/o ^ Ohlins Damper ^ Penske 8987 ^ Traxxion Forks ^ Woodcraft Rearsets ^ PC3usb ^ DJ Quickshifter ^ Radial 6rr Master ^ Galfer lines ^ 1/5 throttle ^ 636 linkage ^ Renthal 15-42 ^ 520 conversion ^ Double Screen ^ K&N Filter ^ Champ Sliders ^ Flexiglass Race Bodywork
nelly250 is offline
post #2 of 6 Old 07-25-2007, 10:29 PM
Stretchy's Avatar
I have been running my ohlins at 4mm over stock with the factory shim but have found i have a serious lack of traction so going to drop it back down a bit and see what i can fix the problem. Had tried everything else to fix it.
I run a 195/70 rear so going to be different to your setup.
Just throwing this at ya cause i wouldnt want you to highside like i did.
Black and Green 05 ZX10R - Race Bike
Stretchy is offline
post #3 of 6 Old 07-25-2007, 11:13 PM Thread Starter
nelly250's Avatar
do you happen to know the circumference or diameter of that big rear tire? The power races that I run have a circumference of about 206 cm which makes the diameter about 60.6 cm
thanks
nelly250 is offline
post #4 of 6 Old 07-26-2007, 06:49 AM
Big Daddy's Avatar
Images: 38
remove the 3mm shim.
Big Daddy is offline
post #5 of 6 Old 07-26-2007, 08:59 AM
Stretchy's Avatar
thanks
According to the Dunlop website it has a max diameter of 656mm.
Look here to compare with other Dunlop tyres- http://www.dunlopracing.com/fitment.htm
Stretchy is offline
post #6 of 6 Old 07-26-2007, 10:49 AM Thread Starter
nelly250's Avatar
i was under the impresion that for the correct swingarm angle that the shim should stay whne running a 190/55 or even 190/55. Could you please go into a bit more detail for me? Also, any reccomendations on where to start with the high speed compresion adjuster?
nelly250 is offline
Penske ?? Big Sexy Performance and Tech 5 04-10-2007 12:34 PM
CF Gaurd for the Penske Hoser Pictures and Videos 0 04-05-2007 02:48 PM
setup hairbear Welcome Newbies! 13 07-21-2006 06:12 AM
penske,fox or wp? livnpaintball The ZX-10R 16 01-02-2005 03:02 AM
Penske is on mad kaw The ZX-10R 27 05-28-2004 05:14 PM
