Gen 1: 2004-2005 The PCV Will it work on Gen 1 - Kawasaki ZX-10R.net
post #1 of 13 Old 04-22-2012, 05:48 PM Thread Starter
Fish_ZX-10's Avatar
I know it has been hinted at as I have been reading, but I have not found any definite answers...
Will the Power Commander V with the auto-tune addition work on a Gen 1 if an exhaust bung is welded in?
I can only imagine the wiring connectors would be the same for the pcIII vs the pcV. If anyone knows for sure, I would greatly appreciate it. I take my bike through a lot of altitude changes and an auto tune would greatly improve things
Fish_ZX-10 is offline
post #2 of 13 Old 04-22-2012, 05:52 PM
Post Whore
-Op-'s Avatar
-Op- is offline
post #3 of 13 Old 04-22-2012, 06:06 PM
SkyDork's Avatar
Op answered your original question, but I gotta ask something. What the hell does altitude changes have to do with auto tune? The bikes ECU already compensates for altitude given the pressure sensor in the air box. Why does everyone think altitude affectS the AFR? I don't get it.
The power will drop with altitude due to less air and subsequently less fuel, but the AFR remains the same. Theres nothing that the auto tune module will be able to do other than fix your AFR. That can be done at sea level or at 5000feet. The AFR won't change enough to re-map the bike half way up a mountain.
#WordCrimes
SkyDork is offline
post #4 of 13 Old 04-22-2012, 09:13 PM Thread Starter
Fish_ZX-10's Avatar
That is a great point, and I appreciate both of your answers. I knew that the ECU would compensate to an extent, but my knowledge of it goes only about that far. So with my logic I was thinking that the PCV would increase its limits.
I do go from Kansas to Colorado frequently and of course there is a drastic change in power as I go up in altitude. I knew that the thinner air in the higher elevation would be the cause of the lack of power, I just thought maybe there would be a way to help the ECU compensate. I now know that my logic was wrong.
In your opinion, would there be any other benefit for me to go ahead with a PCV swap or should I just keep with my PCIII?
post #5 of 13 Old 04-22-2012, 10:19 PM
SkyDork's Avatar
No, not unless you don't have access to a decent tuner and absolutely want to tweak the bike yourself with the auto tune. Or you wanna run the LCD screen, or need 2 different maps. Aside from the accessories and add-ons, the PCV does the exact same thing as the PCIII.
But even then, the PCV auo tune doesn't update real-time. It recommends fuel trim updates all the time, but you still have to hook up to the computer and accept them and download them to the PCV to implement them. So it would offer no advantage to you IMO.
#WordCrimes
SkyDork is offline
post #6 of 13 Old 04-22-2012, 10:24 PM
Post Whore
-Op-'s Avatar
When I get a chance to find a PCV for cheap enough, Im gonna ditch the PCIII and get that + Autotune. Just dont wanna spend a lot on it. That or I might get something to monitor the AFR and tune myself based on readings. Is it worth it? I dont know because I havent done it yet. The PCV offers a greater range of tuning abilities, I believe, compared to a PCIII is another reason. That plus Autotune is enough to entice me.
SkyDork, does the ECU on a Gen 1 actually have the ability to ajust for pressure and air density change? I was always under the impression that the earlier FI bikes lacked the ability to compute and compensate for any change at all.
-Op- is offline
post #7 of 13 Old 04-22-2012, 11:22 PM
OOphLAMEr's Avatar
Send a message via AIM to OOphLAMEr
The best way to compensate for relatively sudden altitude changes is with forced induction...that's that they do with Cesnas and other small aircraft. Otherwise, as it's already been said, as you increase elevation and the air thins out, your ECU is just going to deliver less fuel (to match said lack of air) and you get less power.
Or, you can run super-oxygenated race fuel all the time; or, constantly blast NOS in the higher elevations...but those are probably not good ideas.
Cesna motor...
OOphLAMEr is offline
post #8 of 13 Old 04-23-2012, 02:21 AM
Balogiannis's Avatar
Send a message via MSN to Balogiannis
You are a bit wrong here. The PC-V and autotune are working as real time as it gets. The trim map is just where all the the changes are made and stored,but during the autotune process the bike is actually working on the trim values+basic map. If you add a switch so that you turn the autotune on/off ( that switch can later be used as a map switch,but not simultaneously with the autotune function) you can easily feel or see the difference if you have the LCD screen or if you have the wb2 as autotune.
Balogiannis is offline
post #9 of 13 Old 04-23-2012, 07:49 AM
SkyDork's Avatar
All fuel injection systems have this ability. They have to or they just simply wouldn't work properly. The '00 ZX-12R (first fuel injected bike) had this ability to compensate for pressure changes. The mere fact that the ram air on these bikes means that if the ECU/Fuel Injection couldn't compensate to hold an AFR value, the bike would be horribly lean at speed due to the ram air and horribly rich as the elevation changed. All fuel injection systems have to do this.
Also, the PCV does have an expanded tuning range compared to the PCIII. (100% vs. 1000%). But this will only matter if you're running some really tweaked motor where 100% of the injector duty cycle won't cut it. But then you're looking at higher fuel pump pressure, race fuel, etc. If most of your fuel trim values are 20% or less, what good is having the ability to go all the way to 1000%? :headshake
Cesna motor...
This is only somewhat accurate. That Cessna motor is high-end. It's forced induction, but the lower end Cessna 152's and 172's are normally aspirated carbed O-360 motors. Only the newer models are fuel injected IO-360s. In both cases, there is a mixture control in the cockpit and it's the responsibility of the pilot to manually adjust the mixture in flight to maintain the power level. Best endurance, best power, etc. are different settings on the mixture lever. You have to use the Cylinder Head Temperature gauge to set the power depending on the altitude. Not all aircraft engines are forced induction like this.
My understanding is that you have to accept the recommended fuel trims from the auto tune module to get those to work in the PCV. The auto tune will constantly update and make recommendations, but until those are accepted, you aren't using them. But maybe you are correct on that. Regardless though, it won't be any more accurate or add any power based on altitude changes.
#WordCrimes
SkyDork is offline
post #10 of 13 Old 04-23-2012, 09:28 AM
The only difference when you accept the trims is that all the changes are then copied to the basic fuel map. I'm doing this all the time and I'm sure,PC-V and autotune are real time tuning.
It's also very agressive,if for eg you have afr 11.0 and you want to go to 13.5 it won't make a small change at a time until its get there,it will immediately throw a -30 or so and then adjust from there.You can feel the difference within the first 15 minutes of riding.
I F-d Up At Work Jugg_Head The Out House 27 04-18-2009 07:46 PM
work sucks...work chat dc5rn The Out House 2 07-16-2007 09:51 AM
Free time at work. G work. wingnut Pictures and Videos 4 12-28-2006 06:38 AM
Art work gpz1100 The Out House 6 10-01-2006 07:12 PM
head work / engine work rrdble Performance and Tech 3 01-04-2005 09:27 AM
