Gen 4: 2011-2015 pcv settings with m4 street slayer and maybe air filter. - Kawasaki ZX-10R.net
post #1 of 13 Old 04-15-2013, 09:49 PM Thread Starter
zcar14's Avatar
I was looking through the possible maps for the pcv and didnt find any for the m4 street slayer. I also don't have an air filter but I was gonna get one if I heard good things about adding one over stock. Total mods are -1/+2, ivans wire mod, m4 street slayer, pcv. Does anybody have a similar setup/ advice on the pcv settings? And what improvements did you guys see with a new air filter? Thanks for your help guys!
Engineering school blows.
zcar14 is offline
post #2 of 13 Old 04-16-2013, 06:21 AM
SkyDork's Avatar
I have practically the same mods. +1R, BMC Race Filter, Street Slayer, and wire mod. No PCV and the bike runs fine. Don't plan to add one until I get reflashed. Gains were minimal with these mods.
#WordCrimes
SkyDork is offline
post #3 of 13 Old 04-17-2013, 06:45 PM Thread Starter
zcar14's Avatar
Do you like your bmc or is there another one that you would recommend over the bmc?
zcar14 is offline
post #4 of 13 Old 04-18-2013, 10:58 AM
68gts's Avatar
BMC is a better quality than K&N IMO. I have a great map for your set up at home. I will try and hook you up tonight.
68gts is offline
post #5 of 13 Old 04-18-2013, 12:47 PM
whans1980's Avatar
I have almost the same mods but have the upper flies out and have a m4gp.. I run the autotune..my suggested fuel trims are less than 5 (mostly 1 and 2s) now that i have been riding with it for a while (which meanse it is as clost to perfect as possible) if ya want I can get the map and send it to ya later when I get home
and fyi i have been told by multiple people incl ivan that a air filter makes almost no difference on the gen 4s
whans1980 is offline
post #6 of 13 Old 04-18-2013, 12:49 PM
whans1980's Avatar
the pcv5 and the autotune added a bunch of fuel up top over stock .. and leaned out the bottom quite a bit... im guessing because the flies arent closing. well i dont even have flies. lol
post #7 of 13 Old 04-18-2013, 01:00 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
Have you bought the PCV yet? If you buy it from Ivan, he will load a map into it based on what mods you have...
That's what I did. There is a local shop doing $30 Dyno HP pulls next weekend. I want to take my 10R there and see how Ivan's map performs.
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #8 of 13 Old 04-18-2013, 01:24 PM
whans1980's Avatar
just my opinion but when your already have this much money invested in the bike why would you cut corners and load a generic map that was made on another bike?.. why not buy the autotune or get it tuned? those "custom" mail ordered maps are base maps.. no tbad to get it close before tuning or installing the autotune but to run these generic maps in the long term just doesnt make sense to me
post #9 of 13 Old 04-18-2013, 09:34 PM Thread Starter
zcar14's Avatar
I'd like to get the autotune eventually but I don't have enough cash after buying the pcv. I just wanted a map that would be decent until I had the money for an autotune.
zcar14 is offline
post #10 of 13 Old 04-18-2013, 11:50 PM
ndob1's Avatar
I totally understand your situation . i did the same thing buy a pcv first(from a member here) and then run on the base maps.
i would not run the base maps again - i tried almost everything and they run very rich and bike doesnt perform . So i was runing zero map until i could get it to dyno.
Once dyno the bike is a different beast . Custom map works well and FC vs power is very balanced.
i would suggest just dont run any map for now as they are not efficient at all . may spoil your plug if they run rich . Also my 02 sensor was pretty much coated with dark black residue thanks to downloaded map . once i dyno the bike i had to clean th 02 sensors and they are good now .
just my suggestion.
ndob1 is offline
Tags
air filter, m4 street slayer, mods, pcv, setup
Gen 3: K&N Air Filter (Street) BGoodwin22 Parts, Gear and Accessories 5 08-02-2012 11:32 AM
Gen 3: M4 street slayer lawrence bmx Pictures and Videos 11 06-12-2012 01:44 PM
Gen 4: m4 street slayer BIOHAZARDCYCLES Vendors deals 0 07-05-2011 09:18 PM
BMC Air filter??? Race or Street Vanilla Performance and Tech 13 02-28-2009 07:15 PM
Bmc air filter (street) orecha28 Performance and Tech 4 12-14-2006 07:27 PM
