PCV Firmware update - Kawasaki ZX-10R.net
post #1 of 6 Old 05-22-2013, 01:30 PM Thread Starter
carlo_sg's Avatar
PCV Firmware update
I updated the firmware (V0.1.9.2) on my PCV (and autotune) and there was a very loud POP noise, then the bike would not start.
After unplugging the USB cable the bike started up fine.
I switched the bike off, plugged the cable back in and it started up and PCV software is showing all is well.
Any ideas what went pop?!
carlo_sg is offline
post #2 of 6 Old 05-22-2013, 01:52 PM
SkyDork's Avatar
You didn't update the firmware with the engine running, did you?
#WordCrimes
SkyDork is offline
post #3 of 6 Old 05-22-2013, 03:03 PM Thread Starter
carlo_sg's Avatar
No, engine was off. Ignition was off.
Just the laptop plugged into the PCV
carlo_sg is offline
post #4 of 6 Old 05-22-2013, 03:25 PM
SkyDork's Avatar
Well, that's good at least. Well, if the bike was off, the only thing that could've popped would've been something on the PCV. Did you smell anything burning? Where did it sound like the noise came from?
#WordCrimes
SkyDork is offline
post #5 of 6 Old 05-22-2013, 03:31 PM
eklikewhoa's Avatar
When you update do you have to reload the maps?
eklikewhoa is offline
post #6 of 6 Old 05-22-2013, 03:36 PM Thread Starter
carlo_sg's Avatar
No didn't smell burning. Pop was quite loud. So something must have fried. Will take it for a ride in the morning and try figure out what's not working properly.
Thinking it might have been the resistor that plugs into the ECU when the stock O2 sensor is pulled out.
carlo_sg is offline
Firmware update 68gts The ZX-10R 13 07-07-2012 09:37 AM
PCV Wont update firmware HZRDOS The ZX-10R 6 04-22-2012 11:47 AM
Dynojet firmware update - error. Cocky Rooster Performance and Tech 7 10-03-2010 12:31 AM
GoPro Firmware Update evallarta1 General Motorcycle Discussions 5 09-01-2009 08:05 PM
PCUSB firmware update for multi function hub??? on1whl Performance and Tech 5 04-23-2007 07:22 PM
