Gen 4: 2011-2015 PCV and custom tune after flash? - Kawasaki ZX-10R.net
post #1 of 5 Old 02-24-2015, 02:20 PM Thread Starter
Formerly "bms"
BrandonZX10R's Avatar
Was wondering what kind of performance to expect if I were to add a PCV and a tune to my bike. I know it won't be much hp increase and not to worried about that but the overall feel of the bike. I'm currently running a graves slip on and archers aggressive flash.
BrandonZX10R is offline
post #2 of 5 Old 02-24-2015, 02:39 PM
nakedinseattle's Avatar
If the modifications match the flash, you won't need any further fueling adjustments. If you have things that are different, or switch things out, you will need fueling adjustments.
If the flash you're using, is not for your exact set up, then you should go to a dyno, get a baseline, see how far off it is, and then determine if it's worth the extra $500 it'll cost you for a programmer and dyno tune to fix it.
nakedinseattle is offline
post #3 of 5 Old 02-24-2015, 03:08 PM Thread Starter
Formerly "bms"
My current flash is for a m4 shorty exhaust. So it's almost similar to the graves.
post #4 of 5 Old 02-24-2015, 03:19 PM
SkyDork's Avatar
Not much. But if you have a mail-in flash, it's not perfect for your setup. They never are as each bike is different. If you want the tune 100% for you and be able to make changes after the fact, then you'll need a DIY flash kit or a PCV.
#WordCrimes
SkyDork is offline
post #5 of 5 Old 02-24-2015, 04:12 PM
You can expect around 3-5HP extra on top of what the flash does for you. That's the running average people report back to me after they have it tuned additionally.
You can't get a bike 100% dialed in on any mail in ECU flash service. A lot of them are very good, but ultimately there is likely to be some power gained by tailoring the AFR curve to your bike specifically.
That's why I tell people to at least take the bike in and have it ran across the dyno to monitor the AFR after the flash. Most shops will do this for $50-75. Then, based on the runs you and the tuner can make a sound decision on whether additional tuning is needed and what benefit you'd get.
ZX10RArcher is offline
Gen 3: Custom Tune vs Downloaded (Slip-on + PCV) retell The ZX-10R 3 09-06-2014 12:12 AM
auto tune pcv or custom tune? jkornzx10r Performance and Tech 8 01-06-2014 12:10 PM
Custom Tune vs Auto Tune whans1980 The ZX-10R 64 04-12-2013 08:43 PM
Gen 4: ECU Flash and PCV w/autotuner SoCalNinja The ZX-10R 11 08-21-2011 01:41 AM
Gen 4: pcv auto tune GlenvilleNinja Performance and Tech 0 04-28-2011 05:58 PM
