Gen 4: 2011-2015 PCV+autotune. how to disable the stock 02 sensor - Kawasaki ZX-10R.net
post #1 of 10 Old 03-09-2015, 03:12 PM Thread Starter
m3lelena's Avatar
Unhappy PCV+autotune. how to disable the stock 02 sensor
guys i need help here please:
i have euro spec ZX10R with a PCV+autotune + 2 optimzer,austin racing slip on.
i had the common issue with the software updating the PCV firmware update.
i read the sticked thread and did it again and worked fine..till i sent the bike at the dealer for caring. the tech said when he plugs the PCV and autotune. bike is like having a flu at low rpm. at high rpm everything is fine but as soon as you let go the throttle bike makes this strange sound. it's not like the 4th cylinder power loss.. but when he unplugs the PCV bike is running great...any clue on what is happening? did correct firmware update more than once.. is it related to the closed loop?
Is there a way to disable the stock 02 sensor???? HELP HELP PLEASE !!
m3lelena is offline
post #2 of 10 Old 03-09-2015, 03:17 PM
ZX10RArcher is offline
post #3 of 10 Old 03-09-2015, 03:23 PM Thread Starter
m3lelena's Avatar
Originally Posted by ZX10RArcher View Post
thanks for quick reply
not that one but the one with jumper(?) and resistor
m3lelena is offline
post #4 of 10 Old 03-09-2015, 03:29 PM
I'm guessing that's where your issues are coming from. You may want to phone into Dynojet tech support and talk with them and get the right O2 optimizer.
The jumper and resistor you're speaking of, I'm guessing, is to remove the FI light on the dash from removing the pair valve.
post #5 of 10 Old 03-09-2015, 03:36 PM Thread Starter
m3lelena's Avatar
i have that one too to remove the pair valve located under the seat.
the one i am talking about is plugged where the original 02 wire used to be.
now there is a 02 sensor plugged in the exhaust and straight into the Autotune... hope it clarifies...may be disabling the O2 sensor inside the ECU can help i don't know...
m3lelena is offline
post #6 of 10 Old 03-09-2015, 03:37 PM Thread Starter
m3lelena's Avatar
i have that one too to remove the pair valve unit located under the seat.
m3lelena is offline
post #7 of 10 Old 03-09-2015, 03:41 PM
The one under the seat is the exhaust servo motor.
It may help to see photos of what you got set up there.
You could try disabling the O2 sensor with an ECU flash. I am unsure if that actually removes the requirement or just removes the code and light from illuminating on the dash. Maybe one of the Aussie or UK guys with the Woolich set up can chime in.
post #8 of 10 Old 03-09-2015, 04:06 PM Thread Starter
m3lelena's Avatar
yes pics might help..
i have the servo buddy under the seat
and the grey plug under the fuel tank where the O2 used to be wired when i didn't have autotune..
i think you are right the grey plugs just removes the FI light from dashboard....
Name:	Capture d’écran 2015-03-09 à 23.04.37.jpg
m3lelena is offline
post #9 of 10 Old 03-10-2015, 03:28 PM
peterd10r's Avatar
Images: 7
That is nothing like my Aussie o2 optimizer! Follow your 02 wire up to its male-female connection! Pull apart then the optimizer plugs go to each side! The one you have pictured is called a eliminator!
peterd10r is offline
post #10 of 10 Old 03-10-2015, 03:57 PM
peterd10r's Avatar
Images: 7
Optimiser
This is for your Aussie ZX10R!its what I'm using
Gen 1: HOW TO DISABLE TIP SENSOR AND kS SWITCH??? mosh69 The ZX-10R 1 08-23-2013 09:43 PM
Gen 4: PCV Autotune ZX10RArcher Performance and Tech 8 07-20-2013 01:53 AM
Gen 3: PCV w/ Autotune Nick.INF Parts, Gear and Accessories 7 11-07-2011 10:48 AM
Reflash vs PCV vs Autotune? rayzzr General Motorcycle Discussions 2 06-20-2011 03:22 PM
Gen 3: pcv??? autotune???.... ke2012 Wanted: Buy or Trade 0 06-07-2011 05:53 PM
