PCIII USB Map - Kawasaki ZX-10R.net
post #1 of 4 Old 12-14-2010, 05:56 PM Thread Starter
motoXracer56's Avatar
Exclamation PCIII USB Map
Hi i have an 07 zx10r with a competition werkes gp race exhaust. I was wondering if anyone has a map for this exhaust? Thanks
motoXracer56 is offline
post #2 of 4 Old 12-14-2010, 10:32 PM
Gen2 Ripper
neverendingmods's Avatar
There aren't too many on here using that slipon. Best to try a few different maps off DJ's website and see what works best. I'm getting tuned in spring. My map is for my old setup(slipons) but runs pretty good. Most generic slip on maps are pretty close in their mapping. Just watch what airfilter the map/you are using as the air filter can lean/ richen you up. Custom tune will net you MUCH better gains and rideability.
neverendingmods is offline
post #3 of 4 Old 12-15-2010, 09:37 AM Thread Starter
ok im using a stock air filter and i plan on getting a dyno tune sometime in the spring. I was just trying to figure out what the best map on dj would work the best for this exhaust.
post #4 of 4 Old 08-07-2011, 09:05 PM
SIMPLEGREEN's Avatar
First off Im new here as well so. Hi all. i also run the werkes pipe on my 07 10R. ive found the two bros vale map seems to work well.
SIMPLEGREEN is offline
Tags
commander, exhaust, pciii, power, zx10r
Pciii ZX10Rracer Vendor Deals 3 01-04-2009 02:20 PM
Need a PCIII Map GrtSaint72 Performance and Tech 0 04-11-2008 02:14 AM
Tre & Pciii- Help! John 3:16 Performance and Tech 7 09-05-2006 09:14 AM
MAP for PCIII mad-kaw Performance and Tech 4 10-25-2005 01:47 PM
