PCIII usb losing maps - Kawasaki ZX-10R.net
post #1 of 3 Old 08-04-2005, 07:46 PM Thread Starter
mrzw70's Avatar
When I was at Mid-Ohio for the races I had my bike dynoed and found it to be down on power compared to my local shop and I put this down to dyno differences. The problem is that another guy there told me to check my map as he had lost his several times. He claimed that when you stall the bike while driving that you could potentially lose your map. I had a custom map done and when I got home I found that the map in the bike is the stock (updated in april '04) map. I don't know if his story is true but I do know that my map is gone. I'm going back to my tuner to get another copy of it but this is kind of a pain in the @ss. Has anyone else had this problem or have you even checked your maps, I hadn't untill he told me this. Just wondering.
Mitchel.
Going through life with blinders on and lovin' it.
mrzw70 is offline
post #2 of 3 Old 08-15-2005, 01:40 PM
Still here
ZX10Miami's Avatar
So... have you lost a map again since this post or just a one time thing so far?
Just wondering.
ZX10Miami is offline
post #3 of 3 Old 08-15-2005, 03:23 PM
The map is supposedly flashed to an EPROM, so you should theoretically never lose a map unless the PC is bad.
BNninja is offline
Let the the truth be told PCIII usb GREENDEL Performance and Tech 114 05-31-2007 10:41 AM
PCIII Usb ZX-10R and french system D for save space. jcinfo Performance and Tech 11 11-02-2005 06:04 AM
Are Ivan's PCIII maps any good? DB's ZX10R Performance and Tech 8 07-03-2005 10:05 PM
Need a map for PCIII usb.. on1whl Performance and Tech 3 01-19-2005 09:09 AM
Reprogramming ECU instead of getting PCIII USB? RichTJ99 The ZX-10R 17 10-18-2004 05:16 PM
