PCIII trouble starting - Kawasaki ZX-10R.net
post #1 of 7 Old 03-19-2008, 02:29 PM Thread Starter
livefast's Avatar
Send a message via MSN to livefast
I installed a PCIII a little while ago and the first thing I noticed is the bike takes much longer to start when cold. Just wondering if anyone had some insight as to why this would be, as the map I am using has no adjustment at anything below 1500rpm, or 0% throttle.
livefast is offline
post #2 of 7 Old 03-19-2008, 02:40 PM
ninja44's Avatar
My 06 ran Ivan's map and it was a lil harder to start the first time of the day. I think the map might be a lil rich off idle.
ninja44 is offline
post #3 of 7 Old 03-19-2008, 04:27 PM
Larry Grogan's Avatar
Images: 14
My '05 was hard to start after I installed the PC III. If I press the start button immediately after turning the key to run, while the pump is still priming, it starts up quicker than if i wait until after the pump stops.
Larry Grogan is offline
post #4 of 7 Old 03-19-2008, 05:42 PM
Drain Fade's Avatar
+1, once it's warm it starts up immediately. If it's cold it takes a bit longer to start.
Drain Fade is offline
post #5 of 7 Old 03-19-2008, 05:52 PM
Retired post whore
Alien10's Avatar
I noticed my 04 did the same thing after the pcIII install - its just the first start of the day.
Alien10 is offline
post #6 of 7 Old 03-19-2008, 09:27 PM
sextaafondo's Avatar
Even harder with the ignition module. FI blinks sometimes at start up after pressing the start button, and engine wont start. Ignition key off and back on solves this erratic problem
Dynojet software bugs.
sextaafondo is offline
post #7 of 7 Old 03-20-2008, 12:08 AM Thread Starter
livefast's Avatar
Alright well good to know at least I'm not the only one.
livefast is offline
this 6r rider is in trouble hesaves0211 Pictures and Videos 12 01-20-2008 06:54 PM
I am in trouble now.... Vehicle 1 Welcome Newbies! 23 11-29-2007 03:22 PM
Trouble?? Ken B Performance and Tech 4 04-15-2007 11:24 PM
Having trouble with the classifieds!!! Superbike1 The Out House 10 01-27-2007 09:15 AM
The 1 is having trouble... kawiman88 The Out House 5 06-01-2004 12:09 AM
