pcIII no lights - Kawasaki ZX-10R.net
post #1 of 4 Old 09-18-2010, 10:27 PM Thread Starter
pcIII no lights
Ok I got a pcIII usb and ignition module. Installed everything, hooked it up to my computer ignition(key) off using the 9v battery. everything work as it should.
First night everything seemed to work perfectly. Using a supplied map took the bike out and it ran like a raped ape.
Took the bike to get tuned (the shop no longer does it, long story) so I brought it home to play with a couple different maps. Hook everything up, plugged in 9v battery and nothing. No lights on pcIII, red light on ignition module.
The computer did recognize it as the Serial number displayed and it was able to read the map, but it didn't recognize the ignition module.
I brefly looked over the bike to see if anything had shifted no such luck.
Anyone know what going on?
parisdreams is offline
post #2 of 4 Old 09-18-2010, 10:28 PM
09zx10miami's Avatar
Check your ground.....
09zx10miami is offline
post #3 of 4 Old 09-19-2010, 09:58 AM Thread Starter
Checked ground. don't see any problems there. bike still start and run like a top, but I am pretty that it is not working though.
post #4 of 4 Old 09-20-2010, 04:47 PM
Check your firmware and make sure they're up-to date.......
Adding switches to head-lights and running lights Petrus Performance and Tech 1 06-18-2010 12:15 PM
HID lights jryanfallon The ZX-10R 10 04-23-2009 07:30 AM
How to wire up signal lights as running lights? bchandler The ZX-10R 9 06-09-2008 12:23 AM
Two lights are better looking than 1... xxxxxxxK--D The ZX-10R 42 04-27-2007 02:35 AM
hid lights zx10r85 The Out House 3 02-09-2007 08:18 AM
