PCIII ? on accell pump - Kawasaki ZX-10R.net
post #1 of 4 Old 05-13-2007, 03:42 AM Thread Starter
Donjie's Avatar
does anyone have the accel pump feature on the PC3 set up in your 06/07 zx10r? I have done some searinching and can't seem to find any info. I had this set up on my 636 and worked great? what is your setting?
I have the akra, atre, K&N and Im not sure what setting to use?
Thanks in advance
Donjie is offline
post #2 of 4 Old 05-15-2007, 02:51 PM
inappropriate
hesaves0211's Avatar
Images: 67
dont waste your time with it.
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #3 of 4 Old 05-15-2007, 04:30 PM
Supercharged Mod
Modern fuel injection systems recalculate the required injector duration on *every* rotation of the engine for the next intake stroke. Computers are pretty fast nowadays. There is no need for an "accelerator pump" function because there is no delay for it to compensate for.
I reckon that if fiddling with the accelerator pump function gives a positive difference, then your base map is incorrect.
GoFaster is offline
post #4 of 4 Old 05-15-2007, 05:55 PM Thread Starter
Donjie's Avatar
thanks for the input
Donjie is offline
PCIII USB accelerator pump upgrade GT ZX10 Performance and Tech 4 01-17-2010 10:10 PM
Accelerator Pump on PCIII 06450F Performance and Tech 2 02-06-2007 07:27 PM
Who's using the accelerator pump on PCIII phatkid Performance and Tech 4 05-04-2006 06:28 AM
Accel. pump feature @PCIII majtii Performance and Tech 1 05-30-2005 03:31 AM
PCIII USB - new Acclerator Pump feature bikerscum The ZX-10R 10 02-09-2005 05:39 PM
