PC3 zx10r help - Kawasaki ZX-10R.net
post #1 of 14 Old 07-03-2005, 11:52 PM Thread Starter
JOHNH's Avatar
Send a message via Yahoo to JOHNH
PC3 zx10r help
I installed my pc3 today and now my fi light is on I cant get my bike over 7000 rpms I have the ivans tre a slip on and a k&n filter does anybody know what is wrong
JOHNH is offline
post #2 of 14 Old 07-04-2005, 07:48 AM
Double-check your instructions and your connections. Usual things that cause this are plugging the large PCIII connector into the wrong harness connector and/or wiring the TRE incorrectly. Either will throw an FI light.
CanyonCarver is offline
post #3 of 14 Old 07-04-2005, 08:11 AM Thread Starter
JOHNH's Avatar
The tre was installed about 2 weeks ago and no fi light the fi light only came on with the insall of the pc3 I disconnected the pc3 and my fi light is still on what do I have to do to get it off
JOHNH is offline
post #4 of 14 Old 07-04-2005, 08:20 AM
Sim probs
Dude I had similar problems to this when I installed my TRE. I found out I had pluged the TRE into the wrong side of the connector. As above check the plugs and connectors. Just make sure they are plugged in on the correct side of the male / female plug. I know it's a bitch having to take the tank off but it is worth it when you get it sorted!
Stevo is offline
post #5 of 14 Old 07-04-2005, 08:25 AM Thread Starter
JOHNH's Avatar
when you changed the plugs did the fi light light go off
JOHNH is offline
post #6 of 14 Old 07-04-2005, 08:29 AM
Yeah. My mate and i could not understand thhe prob. We thought it was a dodge unit. Once it was in thhe right plugs it went off.
If i remember rightly the two connectors were on the seat side of the duel rail!
Stevo is offline
post #7 of 14 Old 07-04-2005, 08:54 AM Thread Starter
JOHNH's Avatar
the tre has been installed for about 2 weeks befor the fi light came on I think I have it hooked up right the fi didnt come on until i installed pc3
JOHNH is offline
post #8 of 14 Old 07-04-2005, 09:26 AM
zx-7rking's Avatar
Did you connect all the connectors back up after the PCIII instal. Check the airbox temp sensor. That will throw a FI light. IF Everything is hooked up. pull the code out of the ECU.
BK
05-ZX10R
2K ZX-7R
01' ZX-6R<-- Wifes
zx-7rking is offline
post #9 of 14 Old 07-04-2005, 12:55 PM Thread Starter
JOHNH's Avatar
Thanks guys I moved the sensor back to stock(step5 tre install) all is good light went off runs fine map seems a little soft though.
JOHNH is offline
post #10 of 14 Old 07-04-2005, 06:57 PM
Get it mapped on a dyno. You'll be glad you did.
Birdman is offline
Fugging fishy...Blue 10r on the Ebay Alex31 The ZX-10R 7 04-02-2005 03:30 PM
FS: ZX10R Parts - good stuff! Lyzic Parts, Gear and Accessories 0 03-27-2005 02:53 AM
Group buy on pazzo levers... R1GSXRKILLER Vendors deals 29 02-28-2005 10:12 PM
It's official R1GSXRKILLER The ZX-10R 9 02-22-2005 09:09 PM
Some driving test`s with the ZX-10R Mike_P Netherlands Archives 16 01-07-2004 12:10 PM
