PC3 failing... - Kawasaki ZX-10R.net
post #1 of 31 Old 07-25-2005, 09:10 PM Thread Starter
jrsjkd's Avatar
PC3 failing...
I dunno if anyone has heard of this before.
My PC3 is heating up and failing. After the PC3 heats up, it is causing one cylinder to not fire which is causing that cylinder to blow the gas through the exhaust and consequently bogging and smoking.
jrsjkd is offline
post #2 of 31 Old 07-25-2005, 09:16 PM
Big Daddy's Avatar
Images: 38
was this the diagnosis from the shop??
Big Daddy is offline
post #3 of 31 Old 07-25-2005, 09:34 PM
Austin10RPowers's Avatar
Don't sound like a PC....
Austin10RPowers is offline
post #4 of 31 Old 07-25-2005, 09:35 PM
Remove the PC3 and see if it does it...(maybe you already did?)
post #5 of 31 Old 07-25-2005, 09:39 PM Thread Starter
jrsjkd's Avatar
It makes sense in a way. The first time the symptoms happened, the bike was in the sun for couple hours. bike failed within two miles.
second time, the bike was shaded. The symptoms didnt apear till i got stuck in traffic out in sun. thats why it took longer.
They thought that it was the fuel injectors themselves, but they tested each individually and found no problems.
Ill have more detail tomorrow when i pick up the bike.
jrsjkd is offline
post #6 of 31 Old 07-25-2005, 10:02 PM
rocketracermike's Avatar
wow!. It's hot here and i'm planing to take my bike in for pc installed and dyno run. it must be just a bad pc
rocketracermike is offline
post #7 of 31 Old 07-25-2005, 10:05 PM Thread Starter
jrsjkd's Avatar
im guessing its jsut bad...was kinda wondering if anyone else has heard of something like this
jrsjkd is offline
post #8 of 31 Old 07-25-2005, 10:09 PM
is the pc cover on warrenty.
post #9 of 31 Old 07-25-2005, 10:19 PM
10 speed's Avatar
just some info from a 12 volt guy. When capasitors heat up they fail. Causing heat.
2 if a ground is weak the pc will have to work harder {creating heat}. try mounting the pc in a cooler location. now being the king of not useing the search button...sorry. there is a thread here about mounting the servo in the plastics and opening up a nice spot far away from the engine to mount the pc. then ground it real well.
3 heard rumors that there is a very simmilar plug hook it up and toast a sensor.
4 all electronics are not made the same there are defects.
So there ya go good luck man!
10 speed is offline
post #10 of 31 Old 07-25-2005, 10:45 PM
Post Whore
El Diablo's Avatar
Moved to tech... I've heard of this on busas. Not exactly uncommon unfortunately.
El Diablo is offline
FS: Akrapovic Evo 2, PC3, TRE TheTurd Parts, Gear and Accessories 16 08-03-2005 10:29 AM
PC3 zx10r help JOHNH Performance and Tech 13 07-06-2005 10:25 PM
Akro evo2 pc3 map calhounzx10 Performance and Tech 5 06-24-2005 01:43 AM
Plug-in location for PC3 USB vegasdude The ZX-10R 2 06-14-2005 04:08 PM
Problems with my TRE and PC3 Georgia Boyz The ZX-10R 26 03-12-2005 10:22 AM
