PC111USB, Ignition Module and Speedo Healer - Kawasaki ZX-10R.net
post #1 of 12 Old 12-28-2005, 11:16 AM Thread Starter
coach's Avatar
Just finished installing all these items and I found a good place for all of them. You have to move your tool kit to the rear compartment to fit in the PS3 and the Ignition Module but apart from that they all fit very neatly. The only place I could find for the Speedo Healer was beside the battery as the cables were not long enough to put it with the other two. I have the remote button mounted inside the dash above the speedo so there is no need to have instant acces to the main module of the Healer, I have gone with -12.2% correction as mentioned elsewhere on this board as I have a 16T front Sprocket fitted. I will take some photos of where they are installed later tonight and post them (if I can figure out how to do it).
Sorry I didn't take any as the installation progressed but I did sort of follow instructions that had already been posted here but with my own variations.
coach.
Not enough room here to list everything.
coach is offline
post #2 of 12 Old 12-28-2005, 11:53 AM
sneaky's Avatar
I put my Speedohealer inside of the black left side panel under the seat, close enough to make it to the connections and easy for me to pop off the cover and mess with it if needed.
sneaky is offline
post #3 of 12 Old 12-28-2005, 12:32 PM
circusnuts's Avatar
Need I say more?
Dress for the slide & not the ride
circusnuts is offline
post #4 of 12 Old 12-28-2005, 12:39 PM Thread Starter
coach's Avatar
I'm going to show my ignorance now, how do I post the photos I've just taken.
coach.
coach is offline
post #5 of 12 Old 12-28-2005, 01:08 PM
sneaky's Avatar
Make sure they are in jpeg format and when you post you have to use the "Go Advanced" button and there is a button you can click on to upload from your pc to the site. A new box will open up, find the file, click upload, then close the box when done and then finish out your post and click reply and it should post the pic.
sneaky is offline
post #6 of 12 Old 12-28-2005, 01:38 PM Thread Starter
coach's Avatar
I must be blind as well. Where is the Go Advanced Button?
coach is offline
post #7 of 12 Old 12-28-2005, 01:53 PM
Important question is did you notice any difference with the ignition module?
green 10r, Akro EVO 2, Hyperpro rsc, tre, pcIII, Puig DB, K&N, Purvision HIDs, Speedohealer, GONE
08 Ducati Hypermotard S GONE
08 Kawi Concours 14, Area P full sys, PCV, Flies out
speedfreak is offline
post #8 of 12 Old 12-28-2005, 02:17 PM Thread Starter
coach's Avatar
Can't say yet, 2" of snow lying outside. Probably won't know for sure till March. Can't Wait.
Do you know where the Go Advanced button is?
coach.
coach is offline
post #9 of 12 Old 12-28-2005, 02:19 PM
Post Whore
1killer1liter's Avatar
Images: 11
Right next to the post quick reply button.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #10 of 12 Old 12-28-2005, 03:01 PM
circusnuts's Avatar
I'm interested in seeing how this works for you. I have my healer behind the left front headlight and the fork tube hits it whenever I have to maneuver the bike between the tricycles and bigwheels parked in my garage :headshake
