pc usb problem - Kawasaki ZX-10R.net
post #1 of 4 Old 10-29-2005, 03:25 PM Thread Starter
pc usb problem
heres one for ya, went to change maps today and realized the throttle position said -11 at closed throttle. Now i already changed it a long time ago and it read o percent when i set the throttle position every time!! everything works fine, and its communicating fine with the labtop except the throttle percentage will not move even after setting it back to 0 percent at closed throttle. the rpms read right when i turn the throttle and it changes maps fine but the values dont change at all in the throttle position???? im very familiar with the pc and use it alot. this is the first time i ever seen this. no matter how many times i try it, the values dont change at all even when opening the throttle and yes the bike is running. bike runs fine, wide open it runs good. but the throttle percentage wont move, even when i go to reset the throttle position it wont move no matter what. labtop shows rpms moving perfect but not throttle percentage. it just stays on 0 when opening, and the values are set right.bike runs good but im wondering since the values dont change on the throttle percentage if the pc is just going of 0 percentage???
live on the edge.
crazyman1 is offline
post #2 of 4 Old 10-29-2005, 03:47 PM
Big Daddy's Avatar
Images: 38
moved to tech
Big Daddy is offline
post #3 of 4 Old 10-29-2005, 08:51 PM
Images: 7
My first thought would be to contact Dynojet on Monday. In the meantime you could try re-setting all of your PC connections on the bike.
Ground Zero is offline
post #4 of 4 Old 10-30-2005, 07:37 AM
Check the PCIII connector under the tank that grabs the TPS signal. Should be the smaller connector. Sounds like you've lost your signal -- probably a bad connection.
CanyonCarver is offline
Let the the truth be told PCIII usb GREENDEL Performance and Tech 114 05-31-2007 10:41 AM
Anyone had a Problem with their Throttle Sticking garageworks The ZX-10R 17 09-13-2005 03:09 PM
Does this sound like a generator problem?? po boy Performance and Tech 22 08-24-2005 08:22 AM
PCIII usb losing maps mrzw70 Performance and Tech 2 08-15-2005 03:23 PM
Problem with Sato Pipe ballsup The ZX-10R 13 04-05-2005 07:15 AM
