PC III problem ??? HELP - Kawasaki ZX-10R.net
post #1 of 13 Old 05-27-2007, 07:21 AM Thread Starter
I bought a used PC III who supposed to worked, but....
Maybe I do something wrong somewhere,
I connected all the wire etc and the ground. Put the usb cord on the PC III start the computer= nothing ?????
So I put the switch on, on the bike usually with the stock thing the butterfly on the air throttle body jerk a little bit and slightly open, now with the PC III on = nothing.
Open the C file on the computer try to open the file I download from the Dynojet site=nothing except that the computer don't found the program to read the file.
So I just think finally, that maybe originally when you buy a PC III it come with a CD of some sort to download a programm ????
Or maybe I do a stupid thing and bought a used useless PC III.
HELP...............
ninja_12r2000 is offline
post #2 of 13 Old 05-27-2007, 07:40 AM Thread Starter
Well
I just can't open the file I download on the computer, adobe don't open it.
I put Adobe thing but still not open it , HELL..........
post #3 of 13 Old 05-27-2007, 07:41 AM
you either have to use the 9 volt battery or run the engine to power the pc3
road-runner is offline
post #4 of 13 Old 05-27-2007, 08:12 AM Thread Starter
Run the engine ????????
Putting the key on wouldn't give any thing ??????
Thanks for the tip I.ll try this afternoon. If it just that........
The 9 volt thing adaptor where I can found it ??????
E bay ?????
post #5 of 13 Old 05-27-2007, 08:48 AM
when you just turn the key on the green indicator should scroll up once and down once then nothing that's why you need the 9 volt the connector should have been given to you it comes with the unit. I've heard that you can change the maps with the engine running instead though
post #6 of 13 Old 05-27-2007, 09:10 AM Thread Starter
Nope
I got to look closely to see what you tell.
But no as I bought it used the guy don't send me the 9 vol adaptor so I got to buy it.
post #7 of 13 Old 05-27-2007, 03:04 PM
you hae to have bike running or the 9 v0lt connector,also make sure you have a good ground or the bike wont start
07BLUE10R is offline
post #8 of 13 Old 05-28-2007, 01:07 AM
technic's Avatar
Is it an 04-05? is the FI light flashing?
technic is offline
post #9 of 13 Old 05-28-2007, 01:24 AM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
Did you make sure that you got the Canadian model PCIII? It's supposed to run on Canadian air only, eh.
http://i117.photobucket.com/albums/o45/josh10r/IMG_0144-1-1-1.jpg
Sent from your mom's IPhone using dirty fingers
SUPER K is offline
post #10 of 13 Old 05-28-2007, 01:48 AM
MIA Ex-Mod
Tread70's Avatar
You need to download the Dynojet software to read the maps and also to install maps into the power commander.
http://www.powercommander.com/powerc...downloads.aspx
After you install the software, plug the USB cable to the PC3, open the software, crank the bike; in the software, you should see some input from the RPM lcd on the display.
Tread
Tread70 is offline
Problem with 10R Va zx10r The ZX-10R 15 05-09-2007 03:52 PM
This is a problem!!!!!***NWS*** ninjamaster6-10 Adult Content - Photos / Videos - N.W.S. 15 11-12-2006 05:04 PM
bit of a problem fastburnzx-10 Performance and Tech 24 08-25-2006 05:34 PM
First problem..... mach_man_187 Performance and Tech 24 08-24-2006 06:08 PM
Got problem need help hangman39 Performance and Tech 14 05-18-2006 11:51 PM
