PC III Install Questions? - Kawasaki ZX-10R.net
post #1 of 3 Old 04-28-2008, 10:07 AM Thread Starter
Question PC III Install Questions?
New to ZX10R and honestly to fuel injected bikes overall. I have had old school gixxers with flat slides and different tuning. I have questions on my first PC III install.
Does tank require to be emptied to be hinged up to get to connectors?
Do I map this prior to putting on bike?
Do I download map and put it on PC III directly?
Where do I get the map for my BOZ B2?????or just open heaeer map, basically same thing.....
Any tips fjro install???Thanks
SAkI is offline
post #2 of 3 Old 04-28-2008, 11:19 AM
nite-ryder's Avatar
1. No...The tank doesn't need to be empty. But my personal preference is to remove the tank all together. It doesn't take much more, and it give you a lot more room to work with.
2&3. If you don't have access to a laptop, then the only way to get the map on the bike is to put it on the PCIII before putting it on the bike.
4. Powercommander should have a map on their website. If not, try the maps posted by members here.
5. Just follow instructions... It's not too bad of an install.
Good Luck!!
What can I say...I like the factory bikes!
nite-ryder is offline
post #3 of 3 Old 04-28-2008, 01:02 PM
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
A Very EASY Install. +1 Above. Also in the instructions you got with your PC (which I am guessing you should've gotten ; new or used) it is VERY detailed. If you do not have instructions you can DL them from DJ's site.
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
Ram air questions Gunner Performance and Tech 78 11-21-2009 02:32 PM
Sato rearset install questions SUPER K The ZX-10R 18 08-04-2007 07:55 PM
2 questions? tempe_ty Performance and Tech 5 01-15-2007 09:31 PM
Euro Install: Easiest Way to Re-install Inner Liner Under Headlight? IcePick06 Performance and Tech 18 12-30-2005 10:52 PM
Saying hello and a few questions stkr02 The Out House 11 06-22-2005 01:00 AM
