PC Accelerator Pump - Kawasaki ZX-10R.net
post #1 of 3 Old 10-13-2007, 03:33 PM Thread Starter
ZX10Rip's Avatar
PC Accelerator Pump
Anyone try the Power Commander accelerator pump feature? I started to play around with it today. I used the segested settings for street riding as found in the instructions. I know when I had my 1993 ZX7R, with 39mm smooth bores, I had to disable one of the 2 accelerator pumps on the carbs for it to not run rich. Anyone dynoed their bike with this feature?
ZX10Rip is offline
post #2 of 3 Old 10-13-2007, 03:47 PM
Speed Freak
garth285's Avatar
it wont help you with peak power at all, this basically just adds fuel when you whack the throttle but the bikes really dont need it to much.... the ECU knows what your doing and it will do if for you automatically I tried it out and using my data logger i found it would make the bike richen up to 10:1 just about... it is tuneable but id leave it alone... just my $.02
garth285 is offline
post #3 of 3 Old 10-14-2007, 09:54 PM
phastone's Avatar
...pretty much the same thing I was told by couple different tuners. Basically a useless feature.
phastone is offline
Accelerator Pump on PCIII 06450F Performance and Tech 2 02-06-2007 08:27 PM
Who's using the accelerator pump on PCIII phatkid Performance and Tech 4 05-04-2006 07:28 AM
Accelerator Pump coach Performance and Tech 2 01-21-2006 04:09 PM
Accelerator Pump Stevo The ZX-10R 4 05-31-2005 10:25 PM
accelerator pump den Performance and Tech 6 10-03-2004 08:05 PM
