Overheating issues - Kawasaki ZX-10R.net
post #1 of 4 Old 06-20-2010, 06:45 PM Thread Starter
Bayboy's Avatar
Send a message via Yahoo to Bayboy
Overheating issues
Ok..... My baby has been over heatin and I've begun the troubleshooting process.
1. I've checked the fan by takin it off and connectin it to anothe power supply and it works.
2. The overheatin started after I disconnected the Ignition module so went back in and made sure I reconnected everything and all was good.
3. I checked the water pump and as soon as I started the bike it started spinnin.
4. Took the radiator off and there were no clogs, coolant poured out of all the openings.
I truly hope its not a blown head gasket. Has anyone had to have one replaced? How much was your bill? Same with the thermostat I just don't have the means to check it myself. How much did it set you back.
And last but not least, is anyone runnin a MXL Data Logger? I changed some settings and don't know if that could be the culprit.
Callin all the forum Gurus..... HELP!!!!!!
P.S. If you see any mods in my sig that could be the cause lmk.
YES, I KNOW YOUR BIKE IS FAST............ BUT IS IT FAST WITH YOU ON IT!!!!
Bayboy is offline
post #2 of 4 Old 06-20-2010, 06:49 PM
redline659's Avatar
I have a XML but that wont cause the issue. How hot is overheating? Have you changed the fluid recently? A air pocket in the system will cause it to overheat.
redline659 is offline
post #3 of 4 Old 06-20-2010, 06:56 PM Thread Starter
Bayboy's Avatar
It gets up to 245-250! Hot as two sheep fukkin in a wool sleepin bag!
Bayboy is offline
post #4 of 4 Old 06-20-2010, 07:12 PM
Candy08's Avatar
My 3rd gen hit 240s the other day and started flashing. Kinda scared me bc it's never got over 210-215 before
Mods..LOR painted black, Gutted cats, Bazazz ZFI + AFM Autotune, Pipercross Race Filter, Removed Secondaries, Block-off plates, Healtech X-TRE, Driven -1/+2 blk/blue, 1/5th throttle, Titax blue shorties, Galfer GP Series SS brake lines, CA Integrated Taillight, Bikelitez Fender Elim., Puig black Z-racing windscreen, Tapeworks black overlays, Headlight tint, Techspec prot., Driven D3 grips, Hotbodies Flushmounts, CRG mirror, Scorpio SR-i900, Kawi solo seat, 8k HIDs, LSL sliders
Candy08 is offline
overheating? MSguy Performance and Tech 0 03-15-2010 10:51 PM
Need Help 06 Overheating TX06'10r The ZX-10R 56 10-09-2009 02:32 PM
Overheating dardar Performance and Tech 27 09-27-2009 08:41 AM
HELP OVerheating! madskillz Performance and Tech 22 08-02-2008 04:14 PM
Overheating dgoodz Performance and Tech 2 06-23-2006 10:04 AM
