Optimum gearing for daily driver - Kawasaki ZX-10R.net
post #1 of 7 Old 11-13-2008, 09:49 AM Thread Starter
ikaika's Avatar
Alright, I am about to replace my drive chain and both front and rear sprockets. I have posted about this before and did a search also but what would be the optimum gearing for my 08 ZX10R that I use as a daily driver. I commute on the freeway 12 miles each way and other then that, its the backroads and streets. I live in Hawaii so top speed is not important at all. I want more low end torque and want to be able to wheelie more easily. I was thinking about doing the normal -1 in the front, then I thought about just going +3 in the rear and now I have kinda of compromised and was thinking about going -1 front / +1 rear. Is this too much? Your opinions would be greatly appreciated.
Custom FE/CA taillight/TechSpec/Driven D-Axis gas cap/Cox Racing/Champs frame-fork-swingarm sliders/Puig ZRacing/Titax/Woodcraft-Attack case covers/SME rear axle block sliders/Misc carbon fiber/ZG Latigo/HID's/M4 Street Slayer/BMC/XTre/EK 520 MVXZ/+4 Drive Sys/SpeedoHealer/HEL 'Stealth'-Motul RBF600-Galfer pads/KyleRacing damper/Rifleman's/Ivans b/o plates/Q3's/Motul 300v/Engine Ice/Shorai
http://www.maresohana.com/ktrsd
ikaika is offline
post #2 of 7 Old 11-13-2008, 10:07 AM
Postwhore with an 04
bcm0018's Avatar
Go -1F and then if you want more swap out the rear sprocket. Swaping the rear sprocket is much easier and going up 1 or 2 you should be able to use the same chain length I believe.
bcm0018 is offline
post #3 of 7 Old 11-22-2008, 10:10 AM
i am in the same boat you are,i just got a -1 for the front ill try this weekend and see how that does and if i dont like it ill go 3-4 up in the rear and stock back on the front?
rcfreek is offline
post #4 of 7 Old 11-22-2008, 10:40 AM
Sebastian1000's Avatar
-1F/+2R...seems to be a good combination for us 1st and 2nd Gen guys...
1976 250 Elsinore Sold
1997 600R Sold
1976 KZ 900 Sold
2003 1500 Meanstreak Sold
2006 DL 650 Sold
2002 919 Hornet Sold
2004 ZX-10R
Sebastian1000 is offline
post #5 of 7 Old 11-22-2008, 11:02 AM
The chain is the expensive part and the sprockets are the cheaper parts, you might want to try the bigger rear sprocket first, then maybe the bigger rear and smaller front (which is intense). I'm pretty happy with my +3 rear. I went this way because I wanted this ratio and a nicer looking rear sprocket.
Sike is offline
post #6 of 7 Old 11-22-2008, 01:37 PM
yea just have to try and see what you like everybody will be different,i am going more for a drag gear as the streets are getting a little scary to ride with the new laws and stuff here in florida and this thing is a beast and takes every thing i got not to wheelie!!!!!!
rcfreek is offline
post #7 of 7 Old 11-22-2008, 03:43 PM
Supercharged Mod
If you are replacing the chain anyway, might as well go up a few teeth on the rear sprocket and then make the chain have a few links longer than stock. It's easier on the chain if you do it that way, rather than smaller front sprocket.
GoFaster is offline
-1/+2 ok for daily driver ikaika Performance and Tech 30 06-07-2008 04:39 PM
rear hub needed for my daily driver bigzx10 Wanted: Buy or Trade 0 08-06-2007 08:13 AM
My daily driver / tow vehicle zx10r_guy Pictures and Videos 3 12-04-2006 10:18 PM
Whats your daily driver? Pics! colinmitchell111 Pictures and Videos 158 11-14-2006 02:27 PM
Anybody riding theirs as a daily driver... bleed green The ZX-10R 10 04-14-2004 03:23 AM
