Operating Temperatures - Kawasaki ZX-10R.net
post #1 of 33 Old 10-22-2004, 01:13 AM Thread Starter
By any chance does anyone know's the operating temperature of the 10R. I live in the tropics in Singapore and my average temp is about 80 to 90 Deg Celcius. In stop go traffic it can go as high up as 100 Deg C.
The reason I'm asking is that, I'm thinking of getting rid of the thermostat. Appreciate all of your comments.
Sincerely,
David Isaac
David Isaac is offline
post #2 of 33 Old 10-22-2004, 09:27 AM
Andy's Avatar
Images: 25
I wouldn't get rid of the thermostat.
I put a half bottle of Water Wetter in my radiator. The temp doesn't climb as fast now.
Andy is offline
post #3 of 33 Old 10-22-2004, 09:33 AM
to remove the thermostat completely would not let the motor run at utmost operating temperature.....the motor need to heat up in order for certain components to go into closed loop or such....
MAVRIK is offline
post #4 of 33 Old 10-22-2004, 10:03 AM
vegemite's Avatar
david - similar concerns / operating temps in hong kong, especially in traffic, although now the weather has cooooled downa bit, it is not as bad asduring July / August. I am still amazed how quickly the bike goes from 80 to 100 C once I hit traffic. Must try some of that water wetter
vegemite is offline
post #5 of 33 Old 10-22-2004, 04:37 PM
Big Daddy's Avatar
Images: 38
I tried a 1/2 bottle of milk but no help other than foaming.
Big Daddy is offline
post #6 of 33 Old 10-22-2004, 06:13 PM
Andy's Avatar
Images: 25
Better keep an eye on that, it might curdle.
Andy is offline
post #7 of 33 Old 10-22-2004, 09:00 PM
Also you don't want to remove the thermostat because the cooling system does need a certain amount of restriction to adequately allow proper thermodynamic heat transfer between the engine components and the coolant. If the coolant were to flow all the time, you won't get proper transfer of heat from the engine and will develop hot spots in certain areas of the engine; which for aluminum can be very bad. Tricks that some modders do on cars is to use a lower temp thermostat. It allows the coolant to run cooler but not so that there is fast continuous flow of coolant.
ZX10 Guy is offline
post #8 of 33 Old 10-23-2004, 04:38 AM
CountDokoo's Avatar
I live in Singapore too and I think heat is one of the 10R's main weak points over here. Thanks to the high compression (12.7:1) engine we have, temperature increment is an absolute horror in this hot and humid climate.
It's not just us though, the local 04 R1s also suffer from the same problem. (They are on 12.4:1 compression) I have Muzzy's aluminium fan and water wetter installed but that still doesn't really help much as temps will still continue to climb towards 108 degrees in hot and slow traffic.
I've been trying to source for a larger capacity race radiator much like what the CBR1000RR uses for the 10R in hopes of solving this heat problem. Does anyone have a clue as to where I might get one?
CountDokoo is offline
post #9 of 33 Old 10-23-2004, 04:28 PM
mrzw70's Avatar
Put in some engine ice and your temps will go down 5 to 10 degs cel. My friend is using it in his CBR1000rr and his temps actually dropped almost 18 degs far. He checked it a low speeds and while stopped idling.
mrzw70 is offline
post #10 of 33 Old 10-23-2004, 05:16 PM
Send a message via AIM to gladding24
I use deg F, not C, but 108C= 226F. I've seen my bike around 104-106C in the summer at lights(ambient was about 41C) but as soon as I'm moving again she comes down to 82-88C.
gladding24 is offline
