one low beam light - Kawasaki ZX-10R.net
post #1 of 41 Old 02-27-2010, 06:14 PM Thread Starter
one low beam light
im not thrilled with the only one light coming on in low beam, first time i noticed it i thought a bulb was out , i was thinking of getting a bulb that has high and low capabilities and replacing the high beam with that, then run a wire from the low beam to it , so i could have two lows all the time . has anyone already done this ? or know what bulb would work ?
cebu is offline
post #2 of 41 Old 02-27-2010, 09:14 PM
dirt ninja's Avatar
Images: 9
Doesnt work like that homie....YOu can change the housing out so it will work fine but its not as simple as swapping a bulb.
dirt ninja is offline
post #3 of 41 Old 02-27-2010, 09:33 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
This is oh soooooo true, my buddy tried it with no luck.
TMY10ER is offline
post #4 of 41 Old 02-28-2010, 11:52 AM Thread Starter
if you could find a bulb with both high and low beam that fit in to the socket ,you could then run a wire[splice] from the low beam on the right to the low beam pin on the dual light on the left ,.... but finding one that fits is the problem im guessing ? i have not tried to find a bulb to fit yet
cebu is offline
post #5 of 41 Old 02-28-2010, 08:15 PM
dirt ninja's Avatar
Images: 9
I did it with no problem! works like a champ and looks good.
post #6 of 41 Old 02-28-2010, 08:36 PM
logmaster's Avatar
just leave them on bright.
logmaster is offline
post #7 of 41 Old 02-28-2010, 08:50 PM
JVT
If you look at the bulb shield the low side has more shielding, thats the only difference. IMO.
JVT is offline
post #8 of 41 Old 02-28-2010, 08:55 PM
RDLYN13000's Avatar
Images: 38
Problem solved
RDLYN13000 is offline
post #9 of 41 Old 03-06-2010, 06:18 PM Thread Starter
dirt ninja, what bulb set up did you find to work ?
cebu is offline
post #10 of 41 Old 03-06-2010, 06:23 PM
TMY10ER's Avatar
Yes i would like to know also...please? The buddy that i have who tried it might be a semi retarded window licker too cause he swears up n down that swapping the bulbs will not work? i know it worked on my old gixxers but hadn't tried it on the 10 yet.
TMY10ER is offline
WTB: OEM Low Beam Projector 08-10 10r 2Tall2Ride Wanted: Buy or Trade 5 11-30-2009 12:03 PM
H11 HID Conversion Kit 06-07 Low Beam TMAC Parts, Gear and Accessories 15 01-06-2009 12:47 PM
Headlights no low or high beam?? martek Performance and Tech 5 07-11-2006 06:55 PM
Dynamic Color Change Headlight low/high beam zenithRR The Out House 4 10-24-2005 03:40 PM
Low Fuel light....when..? voytek The ZX-10R 18 06-23-2004 08:01 PM
