Oil turned gray - Kawasaki ZX-10R.net
post #1 of 37 Old 05-06-2012, 10:53 AM Thread Starter
Bmore-stunter's Avatar
Oil turned gray
Went to the track yesterday, made two passes on new oil on my 2nd pass came down the return road and the motor started knock so i drained the oil and it came out grey with metal flakes. Could it be that the head gasket was not seated properly which lead to bearing failure ? Prior to this I had a thin head gasket installed and I've made total of 14 passes since then.
Bmore-stunter is offline
post #2 of 37 Old 05-06-2012, 02:15 PM
bun1t's Avatar
Sounds like it. Coolant in the oil will kill rod bearings pretty quick. Did it overheat at all?
bun1t is offline
post #3 of 37 Old 05-06-2012, 02:36 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
Damn that sucks bro,
It's definitely coolant in the oil.
Your gonna have to tear it down, hopefully its just the bearings & head gasket.
Keep us updated.
Sorry that happened to you.
hellsrazor is offline
post #4 of 37 Old 05-06-2012, 02:51 PM Thread Starter
It never out heated
post #5 of 37 Old 05-06-2012, 02:59 PM Thread Starter
Thanks hellsrazor I'm going to start tearing the motor down this week and see how bad it is and I'll give an update
post #6 of 37 Old 05-06-2012, 02:59 PM
SpazOnaZX's Avatar
If the oil were a murky brown, then I'd say it was coolant in the oil... gray is usually a cam getting wiped out, clutch steels disintegrating, or bearing material. Once that fine metal/oil mixture starts getting pumped through the oil system it's pretty much game over for every friction surface or bearing it goes through. :(
Do a quick pressure test on the radiator with the oil drain bolt out to be sure. If you lose coolant pressure and water starts running out the oil pan drain then you have a gasket/head/cylinder leak issue to chase. If not, then you can look for a mechanical part failure instead. Either way, that motor has to come all the way apart. Sorry for your luck. :(
SpazOnaZX is offline
post #7 of 37 Old 05-06-2012, 04:20 PM
hellsrazor's Avatar
Images: 23
I gotta disagree with ya spaz,
I have seen with my own two eyes a head gasket go on bikes and cars
where the oil is a milky white to a grayish color.
Different coolants can make different colors when mixed with oil,
because you have different color coolants.
Orange, green, pink, so on.
And the head gasket is the weakest link in the engine.
So its the most logical place to start.
post #8 of 37 Old 05-06-2012, 05:58 PM
every grey oil drain coupled with loud knocking HAS always been a bearing in my experience(have blown up 3 bikes, and a truck, lol). what caused the bearing to go is a different story!
shortskimper is offline
post #9 of 37 Old 05-06-2012, 11:45 PM Thread Starter
I use engin ice for coolant which is purple so maybe that's why the oil was gray. And how is a pressure test done and how would check to see if a cam was getting wiped out
post #10 of 37 Old 05-07-2012, 12:03 AM
Gen2 Ripper
neverendingmods's Avatar
Gotta pull the cams to check them and look at the caps to see if scoring. Really sounds like you spun a bearing whether crank or whatever. Gotta disassemble motor man. Only way to check and know what all is screwed.
Like was stated, any metal from a badly spun bearing will likely ruin many others.
neverendingmods is offline
FS: XL Black/ Gray Joe Rocket Alter Ego Jacket highsider Parts, Gear and Accessories 4 09-01-2011 05:29 PM
Alpinestars GPU 1pc suit black and gray perforated size 56 MAD6R Parts, Gear and Accessories 6 10-31-2005 02:38 PM
Anyone in SO Cal want to trade black lowers for gray ones Bad MO4 The Out House 0 09-20-2005 07:46 PM
Anyone in SO Cal want to trade black lowers for gray Bad MO4 Parts, Gear and Accessories 0 09-20-2005 07:18 PM
Alpinestars GPU One Piece Leather Suit Black/Gray (Vented) 52 Solo-Moto-Parts Vendor Deals 2 07-21-2005 09:28 PM
