oil question - Kawasaki ZX-10R.net
post #1 of 17 Old 07-19-2005, 08:39 PM Thread Starter
oil question
this may sound like a dunb question but hey i feel better asking here then not knowing.
in checking the oil level through the sight glass where should the level be at. when i stand the bike up the sight glass is completely filled with oil. where should the level be at?? thanks
also i need to know what kind of oil as far as like 10w40 or 20w50 etc... you guys use. thanks
zfactor2004 is offline
post #2 of 17 Old 07-19-2005, 08:51 PM
some use 10-40,, while others use 20-50,, depends on hot hot it is/personal prefrence and raceing,,, im going to switch to 20-50.. and the manual tells you how much to put in,,, 3.7???3.9 L with a new filter. but i fill mine just a smoooosh,,, above center.
AtomAnt is offline
post #3 of 17 Old 07-19-2005, 09:16 PM Thread Starter
above the center of the sight glass?? man mine is way over the sight glass when i stand it upright. this is how the dealer did it. it says on the case that it should have 3l w/filter. also what of switching to sythetic. how many miles before the switch. still trying to figure out what that noise was that i have. i geuss ill have to bring it to the dealers but i wanted to make sure there was enough oil in it first, than im gonna do the oil change and see if that helps.
post #4 of 17 Old 07-19-2005, 09:22 PM
i put a ???? next to the amount,,, i dont have my book here,,, maybe 2.7 or 2.9?? look at your book,,, and i never filled any of my bikes to the top of the site glass
AtomAnt is offline
post #5 of 17 Old 07-19-2005, 10:20 PM
RickRoush03's Avatar
When the bike is stood up, the sight glass should be between 1/2 way to 3/4 way to the top, with a filter change its about 3 quarts, usually a tad more. But the trick is to put in the 3 quarts, start her up for about 20 sec, stop, let the oil get back to the pan, and then check it, that way the oil filter fills with oil when you top her off.
I was using Motul 20-50 but went Amsoil full synthetic 10-40 and man what a difference especially in shifting, so much smoother now.
"Lead, Follow, or get the hell outta my way!!"
Blue 2004 ZX-10R
- 152.5rwhp 77.6rwtq - more than I need
Red 2003 Jack ROUSH Classic #8 of 50
- 375rwhp 381rwtq
RickRoush03 is offline
post #6 of 17 Old 07-19-2005, 10:22 PM
phastone's Avatar
I can't remember for sure where the oil comes to in the sight glass but I put 3 liters of oil in when I change the oil/filter. Seems like it does come closer to the top than the middle though.
As far as switching to synthetic, just about everyone will have a different answer. I usually switch at about 2000 miles. Some people say to wait longer so that the engine and tranny can get fully broken in and others say do it as early as a couple hundred miles. My bikes have always dynoed better than average and I've never had any mechanical problems. I'm not saying my way is the right way, but it has worked for me.
I use 5/30 for trackdays and 10/40 for regular use, by the way. Both Motul.
phastone is offline
post #7 of 17 Old 07-19-2005, 11:35 PM Thread Starter
thanks everyone. i am an amsoil dealer and i was hoping someone else was using it. i think i will wait a bit longer though before doing synthetic ansoil suggested the same thing to me. so i geuss the dealer way overfilled my oil when the bike isnt even straight up yet stil leening it goes up past the sight glass..... idiots
post #8 of 17 Old 07-20-2005, 07:49 AM
Well if your an amsoil delaer, use that stuff, i like it, have it in my car and bike. Didn't think it'd make much difference, but i noticed almost immediatly the shifting was so much smoother and has just become buttery since. Go ahead and switch over at will, i use the purolater puroone 4610 oil filter also.
Blue 2004 ZX-10R
- 375rwhp 381rwtq
post #9 of 17 Old 07-20-2005, 08:36 AM
If you look at the sight glass you will notice two little "tick marks" in the engine case toward the front of the bike. Those are the upper and lower oil level marks. The oil capacity on sticker is for a dry engine. You will always use a little less to reach the maximum oil level. The oil level reading you get is very sensitive to the position the bike is in. It should be level front to rear and side to side. The side to side you can do by just getting the bike to the balance point.
I switched to synthetic (Mobil 1 15w50 car stuff) at 1,000 miles but I did the Motoman break in. I also use the PurOne oil filter but the PL14612 that is a little longer.
swjohnsey is offline
post #10 of 17 Old 07-20-2005, 10:43 AM Thread Starter
i have it on bike stands on the garage floor so its pretty level and its way overfilled then. shit i drained it today and there was almost more than 4 quarts in there. should be just over 3. i poured the used oil into the old quart bottles just to see how much was in there. thats just stupid. again ... idiots
How to change your own oil & filter... El Diablo Performance and Tech 191 04-04-2016 03:10 PM
Sorry, Just want to be sure! OIL Question. modpup The ZX-10R 11 05-05-2005 12:14 PM
How to change your own oil & filter... El Diablo The ZX-10R 1 02-07-2005 11:28 PM
How to change your own oil & filter... El Diablo How To... 1 02-07-2005 11:28 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
