Oil Pan Replacement - Kawasaki ZX-10R.net
post #1 of 4 Old 08-27-2010, 10:44 PM Thread Starter
cweeks's Avatar
Oil Pan Replacement
Alright, hopefully someone can help me out on this.
Well, against my better judgment I purchased the HR1 Riot exhaust for my 2nd gen. I must say it looks and sound pretty nasty! Really cleaned the bike up a lot. However, the company tells you don't lose any ground clearance, that's a lie, a huge one at that! I went over 3" speed bump two nights ago. I new it bumped the can, but I thought nothing of it. Well I took my bike out for a ride two days later and everything seemed fine. I hit a wheelie or two and then parked it in the garage. I come out 2 hours later to head to class on it to a two foot wide oil spill. I was almost as heart broken as when I heard about the BP spill haha. Anyways, ended up the speed bump started a crack in the pan, and the wheelies finished it off. I've just bought a replacement pan, thanks to WOLFE, heck of a seller by the way. So just how bad is it to replace one, I've done a lot of work on the past couple bikes I've had, but never touched anything on a motor other than headers. I'm just not sure if I should try and tackle it myself or take to the stealership. Any input would be much appreciated!!
cweeks is offline
post #2 of 4 Old 08-31-2010, 11:18 AM
its not so bad at all. the hardest part is making sure the plastic sump is still up tight on the oil press regulator when you are putting the new pan up. i would deff pick up a new gasket too though. just in case
general01 is offline
post #3 of 4 Old 08-31-2010, 11:56 AM
^^No Bike Bum^^
cbolton69's Avatar
Send a message via Yahoo to cbolton69
It is very simple for me and I've never replaced an oil pan... worst part was dropping the header to remove 1 bolt
cbolton69 is offline
post #4 of 4 Old 08-31-2010, 12:31 PM
evallarta1's Avatar
If its anything like the 1st gen its not too bad. If you dont already have it, download the manual. It will give you a good guide to follow.
evallarta1 is offline
Replacement Gas Cap for 07 10r The1pdub The ZX-10R 5 09-15-2009 11:08 AM
bar end replacement monstershane The ZX-10R 3 02-07-2008 08:19 AM
Peg Replacement GETMYLOOT The ZX-10R 9 10-11-2007 06:54 PM
06/07 cat replacement greennmean Performance and Tech 2 02-22-2007 03:38 PM
Replacement Oil mods2come The ZX-10R 22 06-14-2004 11:06 PM
