Oil Leak !!!!!!! - Kawasaki ZX-10R.net
post #1 of 20 Old 04-24-2006, 07:11 PM Thread Starter
BANNED
Oil Leak !!!!!!!
i noticed a small oil spot under my bike (04 zx10r) on my trailor the day after i came from the strip. i wiped under my bike and it was a little oil. i rode the bike about 15 miles and there it was again. at first i thought it was a buildup of chain oil dripping off my front sprocket cover. i took the cover off, cleaned all the chain oil buildup and put the cover back on. that was last thursday and i looked today and i have the same spot on the floor under my bike. i looked and it looked like oil comming from a small square box kinda like an oil pan. would it be an oil pan gasket???? what and where is my bike leaking oil from?????????
mikebar4 is offline
post #2 of 20 Old 04-24-2006, 07:17 PM
Big Daddy's Avatar
Images: 38
Perhaps a thorough cleaning with contact/brake cleaner of the underside and then a short 10-15min ride that will hopefully reveal exactly where its coming from.
Big Daddy is offline
post #3 of 20 Old 04-24-2006, 07:20 PM
FuTAnT's Avatar
Images: 7
When you've actually worked out where it's from, just go around and make sure all the bolts are tightened up properly. Don't go ham fisted, just nip them up to make sure any of them haven't come loose. Did you check the sump plug?
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." Albert Einstein
'85 GSX250S -> '96 ZX6R -> '98 ZX6R -> '00 ZX6R -> '03 CBR954RR -> '04 ZX10R -> '02 ZZR250 -> '06 ZX10R -> '08 KTM 990 ADV
FuTAnT is offline
post #4 of 20 Old 04-24-2006, 07:25 PM Thread Starter
BANNED
no i havent checked anything yet. im gonna try to give the underside a good cleaning like you said big daddy and hopefully find out where it is. like i said, when i wiped the bottom side when i first found it, it looked like chain oil. has anyone had this problem before?
mikebar4 is offline
post #5 of 20 Old 04-24-2006, 07:28 PM
FuTAnT's Avatar
Images: 7
I've never had chain oil leaking on the ground, but yeah, it's definately gone just about everywhere else! Usually ends up like a soft tar consistency and works it way down and out through the bike. Unless you're lubing the chain with something really thin, I'd doubt it, plus chain lube works it's way off at speed, not while the bike is stationary.
FuTAnT is offline
post #6 of 20 Old 04-24-2006, 07:38 PM
RickRoush03's Avatar
my baby was leaking a little coolant, not sure why but it just went away, could never see where it came from, i assume the drain hoses, sometimes they just come from odd places. hopefully, its just a bolt that needs a bit more turn
"Lead, Follow, or get the hell outta my way!!"
Blue 2004 ZX-10R
- 152.5rwhp 77.6rwtq - more than I need
Red 2003 Jack ROUSH Classic #8 of 50
- 375rwhp 381rwtq
RickRoush03 is offline
post #7 of 20 Old 04-25-2006, 12:55 PM
avdigigeek's Avatar
I had a gasket leak on the left side on mine.
it was fcovered under the kawi warrenty.
Smiley
nesba # 936 http://www.nesba.com/
CCS # 936 wingnutzracing.com
Sponsors
Twisted-powersports.com
DCDECALS.net
http://ask2geeks.com/
http://www.superbikeitalia.com/
"Being shot out of a cannon will always be better than being squeezed out of a tube.
That is why god made fast motorcycles"
Hunter S. Thompson.
avdigigeek is offline
post #8 of 20 Old 04-25-2006, 02:06 PM
eric's Avatar
i had a oil leak off the oil filter bracket.kawasaki crimped the gasket and i was out of a bike for a week with less then 60 miles on it.
eric is offline
post #9 of 20 Old 04-25-2006, 02:09 PM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
May want to check on the right hand side where the vlave cover gasket is. I have had mine leak their and had to reseal the gasket by taking nearly the whole bike apart....
zx10ragentblack is offline
post #10 of 20 Old 04-25-2006, 04:34 PM Thread Starter
BANNED
good news,,,,i took my fairings off and i had 1 bolt that was loose on my oil pan. i tightend it up and cleaned the whole underside with degreaser. i put the bike on a stand with the engine running until it got to about 200 degrees. i cut the bike off and let it set for about an hour. no oil,,i rode the bike hard for about 5 miles and still nothing. hopefully thats all it was........thanks for the info guys!!!!
mikebar4 is offline
How to change your own oil & filter... El Diablo Performance and Tech 191 04-04-2016 03:10 PM
Problem - Oil Leak at CS Sprocket JLove The ZX-10R 4 04-11-2005 06:49 AM
How to change your own oil & filter... El Diablo The ZX-10R 1 02-07-2005 11:28 PM
How to change your own oil & filter... El Diablo How To... 1 02-07-2005 11:28 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
